Home > Puma (Tdci) > Hot gearbox
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
Hot gearbox
Is it normal that the gearbox get so hot that you cannot touch it? Mine was damn hot today after 150 km with big trailer - doing about 120 km/h. I also noticed - after i removed the cubby box - that I can make I nice cold Staropramen very warm very fast if I leave it where the cubby box should have been - it gets really warm there.
regards
CRJ 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #81287 20th Jul 2011 9:10pm
nicknick
England 2010 Defender 90 Puma 2.4 CSW Tonga Green
Hi CRJ ,
i tow heavy trailers over long distances with my 90 and i have never experienced this.
i usually have a bottle of water and chocolate in the cubby box, neither has got warm.
it could be your handbrake shoes are sticking/out of adjustment which would give you a huge heat build up from the friction but normally you would also get a knocking noise when slowing down caused by the same fault.
or your gearbox is poorly!
Post #81292 20th Jul 2011 9:22pm
CRJ
I am pretty sure it isnīt the brakeshoes. I noticed that the transferbox also gets very very warm - you do not want to touch it! I was thinking about heat from the engine going backwards but not that much! The gearbox seems ok - no trouble changing gears etc.
Regards
Puma 130 - 08- sold
110 CC 2003
Post #81293 20th Jul 2011 9:26pm
nicknick
Hmm its a strange one matey,
can you touch the handbrake drum or is it too hot ? it should be warm but cool enough to touch.
daft question but is there enough gear oil in the transfer box ?
Post #81305 20th Jul 2011 9:42pm
On every Landrover I have ever owned (a fair number now) the gearbox has got hot on a long fast-ish journey or when towing, so I don't think that this is actually unusual. On my Puma, I don't really notice it inside the cab on normal journies, but go for a longish run up a motorway or dual carriageway and the centre tray (no cubby box on mine) is quite warn to the touch and the seatbox behind the gearbox is hot.
If you are towing and running at speed I would certainly expect this.
Remember that a gearbox is not at all mechanically efficient and will generate heat from the internal friction. On the 6-speed Puma box I woudl expect it to run cooler in fifth (ie direct) than any other gear; sixth is an overdrive gear and will generate more heat than 5th.
This is why many gearboxes are fitted with oil coolers.
Post #81321 20th Jul 2011 10:32pm
Landyrob
United Kingdom 2012 Defender 110 Puma 2.2 HT Alpine White
yes that's normal in a landy.....there is not much you can do about it.
i open the engine bonnet to let it cool down after a long day driving.
Post #81322 20th Jul 2011 10:36pm
CRJ
Thanks a lot - that is comforting - i allready saw my holiday pay going in a new gearbox....would rather spend it on Alive...
Best regards
Puma 130 - 08- sold
110 CC 2003
Post #81349 21st Jul 2011 4:47am
22900013A
I can feel the heat through the seatbox on mine when towing, the heavier the trailer, the hotter it gets! That said, I havn`t noticed it inside the cubby box. 2011 110 USW
1973 Series III 1-Ton
1969 IIA 1-Ton
1966 IIA 88"
Post #81362 21st Jul 2011 8:56am
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
My 110 does the same thing. On a drive across Germany last year in 30+ degree weather I thought that I was going to boil to death. You couldn't touch the exposed metal on the back of the seatboxes, it was so hot.
However, I was told over the weekend at Billing that the Noisekiller foam can keep the seatboxes/floor/gearbox tunnel moderately cooler.
I didn't have the funds to get the kit at the time, but it does interest me.
Post #81365 21st Jul 2011 9:30am
MK
+ the exhaust pipe running around Puma 110" SW
Post #81371 21st Jul 2011 10:30am
landy andy
That is correct, works well Thumbs Up Thumbs Up
Andy
Post #81396 21st Jul 2011 1:06pm
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
I did 5000km in over 35 deg cel outside temps, the Land Rover was well overloaded pulling a boat and sitting at 105kph for all but the rough stages of the trip, 500km on very rough dirt road. The hand brake lever got hot as hell, in fact I put the air con on to cool it, but the gearbox seems to have suffered no ill effects at all on our return to Perth. Other than a cooked egr, dust entry and the ongoing Defender moans i.e window rattle its almost trouble free. If the gearbox puts up with this sort of treatment I don't think you will have any heat problems in with it in Europe.
Allan
Post #81428 21st Jul 2011 5:03pm
spudfan
Ireland
Allan
Before I bought the Puma in 08 I had a look at what the Australians thought of it. It was posts like Allan's above that persuaded me to go for it. I figured a Puma in the outback or very long hot journeys would get more abuse than I could throw at it. So if it is good enough for the Australians,it is good enough for me-and anybody else for that matter. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #81450 21st Jul 2011 7:47pm
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
Might be worth checking that your gearbox oil is still in good condition and has not been cooked, turning black.
Oil suffers at high temperatures, loosing its lubrication and cooling properties and can kill the gearbox overtime.
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #81459 21st Jul 2011 8:38pm
CRJ
Thanks for all the replies - will change the oil this weekend, and be happy about having a place to keep my coffee warm...
Regards
Puma 130 - 08- sold
110 CC 2003
Post #81462 21st Jul 2011 8:48pm
