![]() | Home > Puma (Tdci) > Yet another issue....... |
Mongolia Member Since: 23 Jun 2013 Location: Toulouse Posts: 45 ![]() ![]() |
[quote="Naks"]Hmmm, could be a dirty fuel pickup in the tank?
Time to drop the tank and inspect it - there could be crud around the fuel pickup, and when you put foot, the increased fuel flow is compromised by the blockage.[/quote] +1 |
Swollock Member Since: 16 Mar 2013 Location: Wellingborough Northants Posts: 285 ![]() ![]() ![]() |
I had this for two years before finding it was the MAF sensor. If you simply un-plug it it will run, and if the problem stops then its the MAF sensor. Mines been fine for 3 years after replacement, best do a pump reset and injector learn as well.
Also does not come up with any codes. 2008 Defender 110 XS CSW Volvo XC40 Recharge Triumph T120 BMW R1300GS G0UBX |
Adammacky Member Since: 28 Dec 2019 Location: West Midlands Posts: 309 ![]() ![]() |
Ive had the same issue, turned out it was the injector harness plug, water had gotten in and damaged the pins, try starting the engine and while running give the plugs a wobble with your fingers and thats when mine would cut out so when driving if i hit a little bump or something that shifted the plug it would conk out, replaced that and its sorted now.
Took ages to figure it out, sometimes i would drive a 10 mile trip and it would die 6 times within the first mile but then be fine the rest of the journey, other times it wouldnt die once, wound up was an understatement! Good luck hope you find the fault ![]() |
Def Junkie Member Since: 30 Dec 2013 Location: Somewhere in Paradise Posts: 79 ![]() |
Many thanks for all the very useful tips
Markez79 Member Since: 27 Jun 2018 Location: South West Posts: 201 ![]() |
UPDATE:
The issue is still occurring. ![]() I took the Landy to a very good local independent specialist who couldn't find any fault codes plus told me it WASNT the VCV or fuel sensor. He cleaned all electrical parts and it ran well for a period of 2 weeks, however the symptoms happened again this morning: In a 10 min journey this morning it died 3 times but each time in a slightly different way. 1. Slowing down to allow an oncoming car to pass me. Landy stuttered and died. First warning light to come on just before it died was the Oil. Started immediately at first attempt. 2. At set of traffic lights car was mildly hunting at idle. Went to pull off, lost drive and then lurched aggressively forwards as drive kicked in. 3. When at Costa Drive through (!) car cut out when at idle. Again the Oil light was the first warning light to glow. Car started with no issues at first attempt. Worth noting the car was cold but symptoms have happened before when car is warm. Any thoughts? Thanks M |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 ![]() ![]() |
Ok, quite a few folk have said VCV based on their experience. How did the indie dismiss the VCV so easily?
Based on his experience, when a VCV 'goes, it goes' - i.e. it wont show up so sporadically. I can go 500 miles with no issues and then 3 occur within a 10 min journey.
Thanks M |
ior Member Since: 30 Jan 2020 Location: Suffolk Posts: 10 ![]() ![]() ![]() |
Does the ECU need to be re-programmed when the VCV is replaced ? |
fuel tank full or ruining low then your problem starts ![]() |
This morning it was half full with Shell V Power.
Thanks Mark |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17788 ![]() ![]() ![]() |
He's not had much experience of VCV faults then! ![]() |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 ![]() ![]() |
As said before, ignition switch can cause this issue. Tried all sorts of fixes, but new switch and no more problems. 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
PM sent! |
So my issue turned out to be due to a fault in the Common Rail Pump which was replaced and the problem seems to have gone away. I have run it a few days now without the engine cutting out on me ![]() |
