Home > Technical > Landrover Defender - No drive
abb
Hi guys,
I put the car into gear but there is no drive. I have engaged diff lock - and still no drive.
Backgroung:
Whilst driving at 60-70mph, i heard a loud bang - i stopped to look but didnt find anything. I drove back on 30mph - which seemed ok.
Once at home, i engage rear gear and heard loud clunking- I jacked the car up and wanted to check where the problem is coming from, but after a try now there is no drive at all.
I can manually put the lever into gear position - but when i let go of the clutch i dont feel the gear engage. The clutch pedal feels the same to the press as before.
I would appreciate any pointers on what it might be. Can i do the work myself or will i require to lift the car up
Vehicle: Landrover Defender 130 2.2 - 2012 - 50,000miles - Full service recently completed
Many thanks in advance
A
Post #812618 29th Jan 2020 11:41pm
Have you tried going in high and low range? It's possible it can be knocked into neutral there.It may be worth checking drive flanges too but unfortunately it sounds like it might be the Splined Intermediate shaft in the gearbox I think it's called.
(Anyone please feel free to mention the correct name if I'm wrong.)
The splines wear, due to not being factory lubricated, then they wear they can just let go leaving you with no drive at all to all wheels.
Out of interest what mileage are you currently on? ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #812620 30th Jan 2020 12:06am
abb
The car has currently done around 50k miles - but the car had been standing still for a year almost
I changed the rear halfshafts and drive flages last month (to remove the clunking noise) and all oils/ filters including transmission and transferbox.
Would i be able to change the splined intermediate shaft myself? or will it require a lift, and other specialist workshop tools?
how much would it cost (ball part) from a workshop, any idea?
Post #812621 30th Jan 2020 12:10am
Transfer box would need to come out I believe.
Unless you are very competent at spannering and have access to a lift I'd leave it to a reliable experienced garage.
(I would if it was me as the parts are very heavy).
I'm pretty sure the intermediate shaft is about £280 possibly a bit more for the parts exc labour.
But varies depending on what has gone wrong when they investigate.
I am no expert, many members on here are very knowledgable and have probably had the job done so can advise better.
I believe if it is that, that there are two options Genuine or Ashcroft to choose from.
What you have described does sound like the symptom a sudden loss of drive. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #812623 30th Jan 2020 12:31am
LR90XS2011
put it in diff lock and see if it moves, if it dosnt move then intermediate shaft is most likely cause, if it does move put it out of diff lock and ask someone to look underneath when stationary and chocked, put in gear and slowly release the clutch, if 1 of the prop shafts are turning and the car isnt moving then its a diff or drive flange/cv joint at the end that has the turning shaft DEFENDER 90 TDCI XS,
Post #812631 30th Jan 2020 6:37am
abb
There is still no drive in diff lock - before this happened, the car made a grinding noise somewhere in the shafts. It might be unrelated - as i suspect the front UJ might need to be replaced.
Is changing the intermediate shaft something that can be done at home - car only raised on jack stands?
Post #812745 30th Jan 2020 6:27pm
LR90XS2011
wont be uj broken, uj will result in the shaft detaching and being fairly obvious and will still drive in diff lock
there are some threads on here regards changing the shaft, it is a DIY job for a competent person but there are a few tools/workrounds required
suggest a search on here there was a procedure explained step by step from one of the land rover magazines DEFENDER 90 TDCI XS,
Post #812746 30th Jan 2020 6:33pm
LR90XS2011
https://www.defender2.net/forum/topic59735...iate+shaft DEFENDER 90 TDCI XS,
Post #812749 30th Jan 2020 6:41pm
jst
Diff lock light is on with no drive?
Its def in a gear? You can hear gbox rotating?
If so sounds like time to take t box off and check the intermediate shaft. If that's ok, check clutch.
I did mine on floor of my garage, no lift. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #812989 31st Jan 2020 10:34pm
Shorty53
United Kingdom 2012 Defender 90 Puma 2.2 XS CSW Santorini Black
Sound like another scandalous output shaft failure. Many on this forum. Mine was a £900+ main dealer repair. Fortunately covered under warranty.
Post #813155 1st Feb 2020 8:38pm
