Home > Td5 > Td5/Puma rear axle
Rkcorry
Td5/Puma rear axle
Apologies in advance if this has been recently asked, What if any are the difference in term of fitment and ratio with the puma/Td5 rear axle assembly. The td5 having abs.
Post #812178 27th Jan 2020 5:36pm
jst
fitting to what?
td5 axle is p38 diff. if fitting to puma (all of less maybe 130?) or some td5s then same. some early td5 110s had rover diff. ratios are same just different prop lengths and bolt pattern to fit diff.
you fitting whole axle or axle casing and to what? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #812180 27th Jan 2020 5:51pm
Rkcorry
Hi there, The Puma axle is to be refitted into the Td5,
Post #812186 27th Jan 2020 6:30pm
I did this a couple of years ago... puma (or late Td5) axle into a Td5 110 that used to have a salisbury.
Bolts straight in.... ratios are the same. You need the correct propshaft to go with it; puma one is longer...
(^^ Salisbury left, puma right)
Post #812230 27th Jan 2020 9:41pm
jst
so it depends on age of the td5 (and model) if the td5 has the same diff then use same prop. if the td5 has a salisbury diff then as Jamie says new prop needed or 80mm longer bolts..................................... Shocked Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #812307 28th Jan 2020 1:11pm
Rkcorry
Thank you both for the replies, It is a standard axle in both, so hopefully a straight forward so.
Post #812313 28th Jan 2020 2:02pm
