Home > Wheels & Tyres > Disco 1 rims on a Defender
portal pat
Australia 2001 Defender 110 Td5 SW Fuji White
So.....am having a set of the above reconfigured with the centres reversed and offset -30mm. These will replace a set of 8 x 16 -25mm. steelies. I am in a quandary as to what colour to spray them. Traditionally have always had black rims but that doesn't seem to work on the Disco rims. Anyone have pics. of alternative colours? Thinking a dark silver or even a mid-gray. This is my Deefer. Thanks in anticipation.
 Nothing suggests poor workmanship like wrinkles in the duct tape.
Post #805745 11th Dec 2019 7:22am
If it were me, I'd go for white. In fact, I did many years ago when I owned a white 110:
 Darren
Post #805761 11th Dec 2019 9:58am
portal pat
Job done and pretty sure I nailed the paint colour.Works for me anyway.
Post #812117 27th Jan 2020 4:38am
I had a set of reversed disco steelies once on a 90. They were a bit too offset, first puddle would plaster the side of the 90 (espially with 35" simex's!)
Post #812183 27th Jan 2020 6:18pm
Pilgrimmick
Seem to recall years ago that they were not rated for the laden weight of a 110, ok for a 90, but the 110 was too much.
Hopefully I am wrong, but worth checking. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
(Santana PS10 pick up)
Range Rover L322 (Ful fat)
Post #812204 27th Jan 2020 8:15pm
I think you're getting mixed up with Discovery alloy wheels (specifically Freestyle/Tornado), which are only
rated to about 780kgs, from memory. The Discovery steel wheels are much stronger at 1340kgs, which makes them higher that regular steel wheels but not as high as Wolf wheels. Darren
Post #812228 27th Jan 2020 9:22pm
portal pat
Agree. The Disco steel centres are quite heavy. Heavier than the 8 x 16s I replaced. Nothing suggests poor workmanship like wrinkles in the duct tape.
Post #812238 27th Jan 2020 10:22pm
Pilgrimmick
My bad, just remembered something about Disco wheels not being suitable for the 110. Not trying to worry anyone, better safe than sorry.
Now better check the alloys on my 130! 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #812264 27th Jan 2020 11:36pm
Unfortunately, your alloys are the Disco 1 Tornado that I mentioned above. Darren
Post #812265 27th Jan 2020 11:39pm
Pilgrimmick
Better stick on the Mach 5s then. 80" 1948
Lightweight V8
Bowler Tomcat
130 Station wagon
90 300tdi
Post #812268 28th Jan 2020 12:35am
