Home > Td5 > TD5 Wastegate actuator
Andyred90
My wastegate actuator has been sticking and despite plenty of WD40 it still keeps doing it.
Is it possible to replace just the actuator or is it a complete turbo replacement? Cant seem to find one on the web???
Post #530270 9th May 2016 8:29pm
dorsetsmith
Waste gate actuator has big spring that hold wast gate valve shut, as the turbo compresses boots inlet air the Waste gate actuator moves the valve open to dump exhaust gas to readjust boost out Garrett is about the only place you will get one from USA
Post #530282 9th May 2016 8:52pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Try a good penetrating oil like liquid wrench or something similar. WD is NOT a very good lubricant or penetrant. It has many, many applications as we all know but it was designed merely to displace water and coat the outside of rockets to prevent rust while waiting launch inside missile silos. 2020 range Rover Mk IV Autobiography PHEV
2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #530306 9th May 2016 9:50pm
Alfredas
Lithuania 1998 Defender 110 Td5 CSW Baltic Blue
I guess the one that is sticky is not the actuator but the valve it self. Try disconnecting actuator from the valve, than check if the valve moves freely, if not use some oil and wiggle it till it's free. I used few drops of engine oil.
Post #530355 10th May 2016 11:10am
Bps
On my old td5 it wasn't the actuator that acutually stuck it was the valve on the end inside the turbo that had from what I understand had coked up. I removed the heat shield. Undid the actuator rod and then put a set of mole grips on the arm and along with a lot of penetrating oil kept slowly moving it back and forth. It took about 20 minutes. It has a lot more movement than you think. After about 15 mins it was quite free then it it suddenly free'd up even more. Obviously do it whilst its cold. One of the turbo heat shelf mounting bracket bolts can be a pig to undo so it is easier to drill out the 2 rivets on the shield where it attaches to the bracket and either re-rivet or bolt it on when re-fitting
Post #530375 10th May 2016 1:20pm
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
I've just had the same issue with the waste gate but managed to get the arm moving without removing the shield. I was going to remove it but the 10mm headed bolt on the turbo/manifold I feel would have sheered off. I did try but I didn't want another job. Good idea about drilling out the rivets Bps. Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #811617 23rd Jan 2020 12:38pm
excossack
on the bay of e
https://rover.ebay.com/rover/0/0/0?mpre=ht...2863494529 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #811622 23rd Jan 2020 1:35pm
MC84
Got them book marked now! Mike
Ford 100e 1959
Post #811624 23rd Jan 2020 1:46pm
MC84
Just on the back of this, would I be correct in saying to correctly adjust the thumbscrew on the arm would be as follows.....
Wait for the engine to be cold..
Tighten thumbscrew until all play has gone..
Then give it another half turn to allow the actuator spring to put a bit of tension on the arm..
Question Question Mike
Ford 100e 1959
Post #811656 23rd Jan 2020 6:43pm
MC84
Well I did what I suggested and it worked. Truck seems quicker off the mark so possibly the waste gate wasn't totally closed when it was seized. Mike
Ford 100e 1959
Post #812116 27th Jan 2020 3:33am
