![]() | Home > Puma (Tdci) > Alarm BBS sounding |
Sounds like a low battery. The stress of starting has taken it below the threshold at which the BBS cuts in. Darren
The Fox Member Since: 24 Mar 2014 Location: Shrewsbury Posts: 107 ![]() ![]() ![]() |
As above - have experienced the same when starting in VERY cold conditions, or when the battery hasn't been properly charged.
Put it on charge with a good quality regenerative charger (CTEK et al) or take it for a good long run, then see if you still get the problem. If you do - new battery time ![]() |
adolfy Member Since: 01 Dec 2016 Location: Mid Wales Posts: 58 ![]() ![]() ![]() |
I had the same with my 2013 defender after about 2 1/2 years, the only real solution was to replace the original Land Rover battery with a new one. Since I replaced it, the problem hasn't reoccurred.
Jon Land Rover 1950 series 1 Land Rover LWB 1967 series 2A Land Rover SWB 1980 series 3 Land Rover 110 Defender 2013 |
