![]() | Home > Maintenance & Modifications > Heated mirrors |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Great for more than demisting. They also keep the mirrors clear in the wet
![]() Wired into the rear heated screen they work a treat ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20904 ![]() ![]() |
I was going to ask that, I guess the warmth sheds the wet off a bit then.
Interesting you mentioned sharing the heated rear screen switch, I have that on mine but not a heated front screen. I found separate switches for wiring separately Here. Looks like an interesting mod for once that is useful and doesn't costs hundreds of £'s. ![]() How did you find the wire outing though the mirror arm and to the interior? _\Hennessey|Venom| F5/___ ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Litch Member Since: 10 Mar 2013 Location: Oxfordshire Posts: 767 ![]() ![]() |
Had heated screen & mirrors on my 90 for nearly 20-years now.
The convenience of the heated screen needs no comment and the mirrors are the type of thing that you get so used to that when they stop working (turned out to be a dodgy earth) you really miss them. ONE LIFE, GET IT! |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 ![]() ![]() ![]() |
I've had these fitted for a year or so
https://www.mudstuff.co.uk/defender-heated-mirror-elements.html Easy DIY link shows wiring route ![]() |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
I think Roy5695 has just fitted the Optimill lighted / heated ones
![]() 2008 SVX 90 2000 XS TD5 90 |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11026 ![]() ![]() |
Hi What happens if you accidentally break your mirror, can you peel off the element and stick it on the replacement ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2352 ![]() ![]() ![]() |
Well worth fitting. Relatively easy to peel off broken bits.
As above - the elements seemed quite tough so re fitting to a replacement mirror should be possible but they are relatively inexpensive. Just because you're offended doesn't mean you're right.
Thank you to the above
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Optimill mirror arms are brilliantly engineered and look the part, come pre-wires for heated mirrors. You do need to drill holes through your door for a neat install though.
Previous to these I modified my old arms, drilled through the ball joint the mirror head attaches too, then through the rotating part of the arm (the bit that allows you to fold them in)(note- done this way your mirrors won’t be able to fold in due to the cable, the cable would be trapped/cut if the mirrors folded) and out the bottom plastic cap, this then looped under the hinge and through a hole in the door. (I’ll try find some photos) Wires to my heated screen button via a relay. Work wonderfully on a frosty morning and in the wet spray. ![]() Click image to enlarge ![]() Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Very interesting.
The only trouble is you'd need to buy a lower hinge to match as well. ![]() Or can you buy the billet arms only to use with factory hinge? Regarding if the element got broken along with mirror glass, seeing as replacement elements on their own seems to be about £10 - £20 a pair I would see it as an easily replaceable part of needed. Roy - This is a long shot but do you know what current draw the mirror arm (lights).use for the pair? It must be somewhere under 1A I would have thought if they mimic the interior lighting. Glad I started this thread as there seems quite a lot of interest and useful info too. Not so good for the wallet though. ![]() ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Thank you. ![]() Will take a good read though another night. ![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Heated mirrors with turn signal repeaters. Heating element takes 12W to get temp to 50°C.
https://shop.landreiziger.nl/verwarmde-spi...ender.html Just heated mirrors https://shop.landreiziger.nl/verwarmde-spiegels-lr-defender.html Switch cover https://shop.landreiziger.nl/verwarmde-spi...kapje.html Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw Last edited by ericvv on 24th Jan 2020 6:57am. Edited 1 time in total |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
Bearmach make the switch covers but as others have said you may prefer to tap into the heated window instead.
https://bearmach.com/switch-assembly-heate...s-ba-10307 WARNING. This post may contain sarcasm. |
