Home > Puma (Tdci) > Decat and centre muffler removal
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
I am thinking of doing away with the cat converter and centre muffler on my Puma. I did this with the wife's TD5 when i removed the egr and it seems all good. I've heared reports that the Puma doesn't like to run without a cat converter so thought I would check before buying the bits. At this stage the engine tune is standard but this will change in the near future.
Allan
Post #81153 20th Jul 2011 9:02am
Naks
Re: Decat and centre muffler removal
Nah, any TD engine will run better without down-turbo restrictions. Where have you seen reports that the Puma does not like a decat? --
Post #81166 20th Jul 2011 11:14am
K9F
Allan wrote:
I've heared reports that the Puma doesn't like to run without a cat converter so thought I would check before buying the bits. At this stage the engine tune is standard but this will change in the near future. Allan
I did away with rear box and cat as have several others. Allows the turbo to spool up quicker and the engine to breathe better! Plenty about it here:
http://www.defender2.net/forum/topic3204.html?highlight=griffin If you go through life with your head in the sand....all people will see is an ar5e!!
Post #81167 20th Jul 2011 11:37am
Allan
On here, may be when tuned prior to exhaust change? Will go ahead and order the bits I think.
Allan
Post #81188 20th Jul 2011 3:39pm
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
I've removed cat and midle silencer, great sound and better response at low range both with standard and tuned ECU! Thumbs Up Matteo
Defender 110 Td4 SE MY 09
Post #81197 20th Jul 2011 4:50pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Ditto Cool Guns and Landrovers .... anything else is irrelevant.
Post #81265 20th Jul 2011 8:43pm
Allan
Thanks for the help
Allan
Post #81348 21st Jul 2011 3:48am
