Home > Td5 > Ticking noise on light acceleration
turnah
United Kingdom 2005 Defender 90 Td5 HT Belize Green
I'm trying to track down a noise on my 2005 Defender 90 TD5, wonder if anyone can help? It’s a metallic rattle / ticking that only happens when in gear, the clutch is up and I'm being gentle with the accelerator.
I've uploaded a video of it to youtube - https://youtu.be/RI74kSdiwIU
The engine noise drowns it out at higher speed which is a relief, but is really noticeable between 20-30 mph and i'm cruising. Some days it's a lot louder than others - but can't put my finger on a link to why. Revving the engine out of gear or with the clutch down, just hear the sweet TD5 roar. I'd much rather hear this when driving.
Went in an older TDI recently and it didn't make the rattle, so not sure if its a TD5 thing (haven't been in another one) or something else.
On the video:
4 seconds opening vent while accelerating
6 seconds release accelerator
7 seconds gentle acceleration
10 seconds idle
Also i'll add I don't know a lot about engines, but learning a lot as each thing breaks so if i'm being stupid feel free to let me know.
Thanks!
Post #811465 22nd Jan 2020 3:56pm
landy andy
Being honest, I can’t hear anything that would concern me. But I am only listening on an iPhone
Something to check would be the exhaust manifold. These can warp, stretching or snapping the four end studs (two at each end). Check for soot on the cylinder head.
Also check the exhaust flex section.
Post #811471 22nd Jan 2020 4:22pm
excossack
Turbo heat shield rattling? Only just hear a noise. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #811474 22nd Jan 2020 4:51pm
landy andy
Good call with the heat shield. They are always broken or the mounts are.
There is also a little heat shield on the crank sensor that can rattle.
Post #811483 22nd Jan 2020 5:34pm
Bluericky
United Kingdom 2009 Defender 110 Puma 2.4 DCPU Keswick Green
A loose Or blowing injector can make a ticking sound . At least it can on a TDCI and Jeep Grand Cherokee ! https://www.instagram.com/hustynminepark/
Post #811486 22nd Jan 2020 5:47pm
turnah
Thanks for the replies gents, I've checked the heat shields and seem pretty sturdy. More akin to the engine tap noise but speeds up.
The noise I mean is the fast tapping, the same noise slows down on idle at the end of the video. Maybe it's just normal? It's at 5 and 7 seconds on the vid. Just a little tappy. Could it be what the hydrolic tappets sound like?
I had a previous issue with stalling so the o rings were replaced a couple of months ago and tappets wiped down and adjusted at the same time (sorted it) but tapping noise has happened before and after (and the few years I've had it). I've just started listening to music less in the van and notice it more.
Post #811524 22nd Jan 2020 8:34pm
Bluericky
If you had your injectors out at some point then I would definitely just nip the bolts up . They do work lose https://www.instagram.com/hustynminepark/
Post #811590 23rd Jan 2020 10:17am
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
It's the clock.......... Cheers Don.
Post #811591 23rd Jan 2020 10:20am
turnah
Solved in case anyone has the same issue and uses search!
The intercooler had sprung a small leak, fitted an uprated allisport this week and my ticking is no more!
Post #906361 3rd Jun 2021 7:53pm
jmccmick
Canada
Ah well, I was hoping the issue would be something smaller, but maybe that'll help me justify buying a bigger intercooler to my wife. My 2004 TD5 90 makes what I would describe as a rattle, most appreciable in 2 and 3, and less appreciable when under load. Seems to happen between 1300-1800 RPM, a little lower in 2nd and a little higher in 3rd. Don't notice it in 4 or 5. The engines sings at >2000 RPM and ive never had any smoke or overheating so haven't really been concerned, but might go hunting for a leak on the IC. Does that sound similar to how yours worked out ? If anyone has any other suggestions, including "its fine, drive your truck" I would be grateful
Post #907716 14th Jun 2021 3:26am
