Home > Maintenance & Modifications > Metallic Clank/Clunk/Bang
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Morning all,
I was driving around a farm in Yorkshire two weekends ago and I noticed that a loud metallic clang/bang had started on the 90. Now, it’s had a clunk from the rear diff for as long as I’ve had it and I know what that sounds like. This noise is coming from the rear half of the vehicle. It sounds like you’re driving over a particularly loose manhole cover or something under tension is being released and hitting metal. It’s a very metallic noise and, to begin with, I thought it was just metal around the farm that I was driving over. However, it continued on the way home. It happened irregularly but when it did it was when I was setting off, mostly.
Does anyone have an ideas of the cause or has anyone experienced anything similar? I’ve given the car an aggressive rocking while stationary and can’t replicate the noise. I’m going to crawl under with a torque wrench later and check that everything is tight.
For some background, the A frame ball joint was replaced this time last year, along with the rear prop UJs. The rear halfshafts and drive flanges were also replaced with HD units around the same time. The suspension was also changed back in the summer.
Thanks in advance for any ideas! Thumbs Up Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #811267 21st Jan 2020 9:47am
landy andy
Damper rubber mounts, and prop UJ’s would be my first check. Yes you had new UJ’s before, but they can fail.
Post #811270 21st Jan 2020 9:57am
dorsetsmith
The suspension was also changed back in the summer. with new damper bushes Question Question as lower damper bushes fail check if you have movement hear
Post #811271 21st Jan 2020 9:58am
BaronDefenders
Will definitely give the UJs a thorough check.
The bushes were replaced as they came in the OME kit. However, I will check them for wear later today. Charlie
2002 Td5 90 (SOLD)
Post #811272 21st Jan 2020 10:12am
jst
check for perishing where that cap on the rear axle located the bush for the shock. they can cause premature bush damage or people do the shocks up so tight the bush is compressed within the cup and its doing nothing.
if you do any off roading i would remove the cup. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #811273 21st Jan 2020 10:20am
BaronDefenders
OK, I’ve been out and had a look at everything. The prop UJs have zero play in them. The shock bushes are as you’d expect for their age - still fine. The metal cups for the bushes are more like large washers with the OME kit, interestingly.
I’m using the 90 this weekend so I’ll try and replicate the noise and see if I can narrow it down further. Charlie
2002 Td5 90 (SOLD)
Post #811283 21st Jan 2020 1:17pm
Mo Murphy
Did you take the props off to check the UJs ?
That's the only way to check them properly.
50 Shades of Pennine Grey
Post #811298 21st Jan 2020 2:50pm
BaronDefenders
No I didn’t. But I’ve given them a good push/pull and watched them whilst rocking the vehicle. Charlie
2002 Td5 90 (SOLD)
Post #811299 21st Jan 2020 3:01pm
You still won't know what the UJ's condition is like with them in situ.
I found this too, and MOT stations missed it and so did servicing because the prop want taken off to check.
This caused other issues elsewhere and made it more expensive and longer lasting than it need have been.
Just removing diff end would be enough to check though.
Take a look at upper rear damper mounts too, bounce the body and look for play. _\Hennessey|Venom| F5/___
___\⭐️Lone|Star|State/___
____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #811303 21st Jan 2020 3:24pm
landy andy
The obvious has been mentioned by me or others yet.
Is it your rear door, or spare wheel carrier. They are very well known for banging about and require adjustment.
Post #811306 21st Jan 2020 3:38pm
BaronDefenders
I’ll have another look at the UJs then.
I did wonder if it was something like the rear door as, once or twice, it sounded like the noise came from inside. I’ll double check but I think I had a look at the door and carrier last week. Charlie
2002 Td5 90 (SOLD)
Post #811309 21st Jan 2020 4:01pm
landy andy
Jack or wheel brace, where ever that may be, even in the battery box.
Post #811323 21st Jan 2020 5:21pm
BaronDefenders
Ah, it could be actually. I’ve got one of the big Mercedes Sprinter jacks in the seat box and it could have moved slightly. I’ll have a look in daylight. I remember the wheel chock came loose once and sounded like something underneath was about to rattle apart. Charlie
2002 Td5 90 (SOLD)
Post #811329 21st Jan 2020 5:57pm
BaronDefenders
Righto, on my way back from York this clunk has developed . . . It is now a squeak and rattle at low speeds. Am I right in saying that these noises are almost certainly the symptoms of a dying UJ? Charlie
2002 Td5 90 (SOLD)
Post #812062 26th Jan 2020 4:29pm
landy andy
Yep. Sounds like a knackered UJ
Post #812076 26th Jan 2020 7:12pm
