![]() | Home > Maintenance & Modifications > Removing folding seats on a 110 |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Yes the seats and brackets are easily removed - just nuts and bolts
mse Member Since: 06 Apr 2008 Location: UK Posts: 5096 ![]() ![]() ![]() |
They are heavy units to remove, but can be removed yes Mike |
V10 Member Since: 19 Jul 2011 Location: Berkshire Posts: 4 ![]() ![]() ![]() |
Thanks. That's what I'd hoped. Do you know what it looks like when they're removed? Is it just holes or would any brackets be left?
do a search its been discussed and photographed on here before
Not sure if 90 ones are any different to a 110 but I took mine out a couple of weeks ago so here you go... ![]() ![]() I have put a storage box on top so cannot show you that. Most of the bolts can be replaced and will not stick proud as the carpet comes flush with them but as you can see you are left with gaps in the carpet but that's an easy fix ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Massively helpful - thank you
