Home > Puma (Tdci) > Ford part nos for belt pulleys
Does anyone happen to know if there are suitable equivalent Ford parts for the two belt pulleys PQH500100 and PQH500120 (the ribbed and plain pulleys for a 2.4 non-aircon), and if so the Ford part numbers, please?
I'm a bit miffed at the moment - these pulleys had become a bit noisy and the bearing a bit rough on my 245k mile engine (not surprising!), but the brand new genuine LR parts I have just replaced them with, although smoother to spin, actually make more noise than the ones that came off. I'm not impressed at all!
My nearest Ford dealer is about a mile away but my nearest LR dealer is about 30.
Thanks Thumbs Up
Post #810834 18th Jan 2020 11:12am
MMR1988
Germany 2008 Defender 110 Puma 2.4 SW Alaska White
Just change the bearings of the pulleys. This costs less than 5 € per bearing.
Post #810950 19th Jan 2020 10:30am
MartinK
Blackwolf
Can you put a bit more detail please?
I did a bit of digging, and did find a few possibilities, such as https://www.ebay.com/itm/293079526222
http://www.kakapart.com/oem/partscrossinte...00100.html
But drew blanks after...
Cheers Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #811100 20th Jan 2020 7:29am
Thanks Martin. Further digging has lead me to the conclusion that the Ford installations of the 2.4 TDCi use a different arrangement of serpentine belt and use different pulleys, so it is likely that there actually is no Ford equivalent part number of either of these.
The particular pulleys I was asking about can be seen in the picture below (borrowed from another thread where Def2 member Hornet had usefully posted it) and are items 8 and 9 in the picture. There is a further ribbed pulley located to the left of number 8 on non-a/c engines, which is the same part as number 9. The smooth pulley, number 8, is made ion two halves which are rivetted together sandwiching the bearing, and the ribbed pulley number 9 has the bearing pressed in. Both of these use standard 6303 bearings which are both cheap and easily available, but not easy to replace in the pulleys due to the outstanding design!
The fan hub pulley (the big one in the picture) is in theory only available as a complete assembly together with the backing plate and two other pulleys, and a rather shocking cost, but I think that the Ford versions must use a different arrangement.
[/quote]
Post #811132 20th Jan 2020 10:58am
MMR1988
Yes, the serpentine belt is completely different for the Transit engines.
I'll check, if I can find some cross notes in my documents, when I'm back home. Maybe can find some ford numbers.
BTW: The hand written numbers are the bearing types for these pulleys.
Post #811138 20th Jan 2020 11:46am
MartinK
Blackwolf.
As I am sure you've found. There are some sources of data, but I guess the issue is whether you can TRUST it without comparing the items in your hand!
This one for instance: https://www.autodoc.co.uk/spidan/8280645
Quote:
OEM reference number(s) comparable with the original spare part number
OEN 7H12-10A216-AA — FORD
OEN 7H12-10A216-AA — ROVER
OEN PQH500100 — ROVER
If your Ford dealer is that close, maybe pop along and have a look at 7H12-10A216-AA
These look interesting... https://www.ebay.com/itm/New-Genuine-FEBES...100623.m-1
It's like herding cats! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #811149 20th Jan 2020 1:05pm
MMR1988
I checked my notes, unfortunately I have couldn't found a ford part.
The number in the post above is a Ford number, but was not used in a Ford vehicle. Is it is just from the time when LR was part of Ford.
Post #811209 20th Jan 2020 8:24pm
