Home > Td5 > TD5 110 Rear Prop Length
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
After my rebuild on new chassis the rear prop looks to be running over extended on daily use, and the gearbox/transfer box look to be sitting a bit too far forward.
Can someone with a standard 110 Td5 with Salisbury rear axle measure the length of their rear prop when sitting on level ground please.
Thank you
Nigel.
Post #810426 15th Jan 2020 7:56pm
I havn't got the length of the props, but when I swapped from a Salisbury to a 110/wolf/P38 type, the difference was about 8cm longer (longer on the P38 type axle)
Post #810581 16th Jan 2020 6:55pm
Nidge
Thanks for reply and pictures Jim .... but its the actual fixed running length i'm after, from rear diff flange to rear flange on the transfer box, as I suspect my chassis mounts are out and the prop is now running over extended, if you get me.
Nigel
Post #810585 16th Jan 2020 7:10pm
htb2
Shielder chassis?
Post #810589 16th Jan 2020 7:29pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Not gonna go under my 110 today snow melting off it right now in the garage. I have a new on eon the shelf and measured it fully compressed 45 1/4 inches.
Hope that helps. Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #810621 16th Jan 2020 10:24pm
