Home > Maintenance & Modifications > Anyone fitted Koni HT Raid dampers?
bankz5152
Picked up a set fairly cheap to replace the TF rubbish. Though the adjustable side of them is a pita to say the least!
Anyone fitted a set and have a decent place to start with the damping foprce? Instagram @defender_ventures
Post #809993 12th Jan 2020 10:07pm
roel
I used the Koni Heavy tracks on my Camel Trophy Discovery. As the CT disco was very heavy I ended up using the middle setting in the front and the heavy demping setting in the back.
On a 90 depending how much s... you carry and what you prefferences are, I would start somewhere in the middles setting and start from there. Roel
2003 90 Td5 (2009-now)
Post #810030 13th Jan 2020 12:37pm
bankz5152
Going on my 110.
Weights 2.7 ton unladen with fuel. Often heavily loaded when overlanding/transporting kit
Post #810045 13th Jan 2020 2:01pm
roel
My CT disco was 2.5T empty.
Here at Eastnor Castle.
You probably have to play with the setting to get the ride that you like. Roel
Post #810083 13th Jan 2020 5:53pm
ickle
Mine runs either empty or at / over max weight when towing, still on 'softest' setting after several years.
Keith
Post #810085 13th Jan 2020 6:25pm
bankz5152
Tough one then!
Ill set them all to softest wind out a couple clicks and see. Just a pita having to remove the shock to adjust!
Should be able to adjust the fronts in situ id think though Instagram @defender_ventures
Post #810086 13th Jan 2020 6:32pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
I have the HTR´s on my lightly kitted 90 (Recaro CS´s, no rear seats). I run them one click above softest setting, and although the ride is definitely on the sporty side, we find it a nice place to be on long runs. The Koni´s (which are basically truck dampers, according to the service tech) are tough and over dimensioned for our 90. We did however have one pack up a couple of years ago (it was four years old and had about 40 k miles on it) which resulted in them sending us a new pair for very little money. Good service. 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTs,
Recaro CSs, anorak, wellingtons
Post #810097 13th Jan 2020 7:17pm
bankz5152
Thats good news.
Ok cool. Im thinking id prefer a slightly softer ride, do like 350miles a week on mway and country lanes. That said I dont want it so soft I end up with loads of body roll! Instagram @defender_ventures
Post #810106 13th Jan 2020 7:50pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
I have them on my 110 Hardtop. I run the front one up from soft and the rear turned up full. Really depends on your tyres / wheel size / springs as to the comfort as much as the shock settings. Mine is on 16's with 265 tyres. I have the rear's shocks at full as i have a 30mm front roll bar and need the rear stiff to cut the understeer out. I also have helper springs inside the rear springs as standard but its not crashing or banging over bumps, just well planted for a heavy vehicle....
Post #810120 13th Jan 2020 8:52pm
bankz5152
285/75/16 Cooper ST Maxxs no anti roll bars.
Will be coupled with medium/heavy duty +40mm springs on the front and medium +50mm on the rear.
Majority of miles is unloaded but still often full of weighty kit. Instagram @defender_ventures
Post #810125 13th Jan 2020 9:03pm
epictrail
Did you buy the +2 version of the shocks then as you have lift springs?
Sounds like you could try the shocks at standard or +1 click at the front and +2 clicks on the rear and see how you find it. Rears are fairly quick to remove adjust front a little more involved.
Post #810189 14th Jan 2020 10:49am
bankz5152
Yeah +2s
Sounda like a good start! Instagram @defender_ventures
Post #810197 14th Jan 2020 11:44am
bankz5152
All done today!
Fronts at 1.5 and rears at 3. So much smoother, soaks up the bumps well but body roll is kept in check.
Post #810883 18th Jan 2020 6:05pm
epictrail
Excellent Thumbs Up
Post #810888 18th Jan 2020 6:40pm
Site Copyright © 2006-2020 Futuranet Ltd & Martin Lewis
