Home > Maintenance & Modifications > Rear diff options, Road use Ashcrosft ATB? on a Puma?
Page 2 of 2 <12
jst
All my diffs gbox, shaft work comes from Ashcroft's.
Approx 8 lockers, 2 x 9" high pinion diffs, various gbox, t boxes, 2 x atbs, lotanofncvs and shafts, no issues, they get my vote. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #809748 10th Jan 2020 11:40pm
bankz5152
Xcess 4x4 is the one to go for.
Ultrabuild front diff atb £1200 - outright no exchange
Ultrabuild rear diff atb - £1080 - on exchange
Post #809756 11th Jan 2020 8:44am
Stacey007
If I throw in at some point I would like to swap the engine...
An LS3 ideally but I'm also looking into the 335d route.
Would the updated diff be better with these options? It one less thing to upgrade if / when I do?
From what I'm reading here Nigel gets a good report, the pegged maybe overkill but it will last? It's not like I want to be changing this often?
Post #809757 11th Jan 2020 8:52am
LR90XS2011
with an LS3 or 335d you will certainly want robust diffs front and rear DEFENDER 90 TDCI XS,
Post #809770 11th Jan 2020 10:24am
BogMonster
Falkland Islands 2015 Defender 110 Puma 2.2 USW Corris Grey
I've got ATBs front and rear in my 300Tdi, rear is an Xcess pegged diff built by Nige, front was a DIY rebuilt diff that popped the original centre when quite new. Xcess not cheap but worth it. Not sure I needed it pegged but decided I may as well as I intend to keep the vehicle.
The only noticeable feature is that with the front, when you first set off and the oil is cold the steering feels slightly stiffer, that's gone within 2 minutes and feels fine after that. You also get a slight gear noise when the diffs are working.
I can't say I have really tested them yet, but climbing off road on loose surfaces is amazing, just doesn't want to spin a wheel. ---
2006 Defender 110 SW 300Tdi • 2011 Ford Ranger XLT crewcab • 2015 Defender 110 Station Wagon Utility TDCi
Post #809780 11th Jan 2020 11:18am
2010Blackdefender90
United Kingdom 2011 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
Tested my Ashcroft ATB’s, front, centre and rear last weekend at Cannock Chase... first time off road with them.
Thoughts so far... off road, unstoppable, in mud, gravel, water, or steep hill climbs, not once did the T/C kick in. Solid, stable and sound footed off road.
On the road, slight heavy steering, but you get used to it. In the wet, unstoppable, zero ABS or TC and plots through deep puddles as if they are not there.
Lastly, zero clonking and backlash in the drivetrain in any situations.
My set up is Ashcroft ATB’s front, centre and rear. Ashcroft output shaft - gearbox to transfer box. Ashcroft HD drive shafts front and rear, Drive flanges and lastly, their HD CV’s.
Thumbs Up
Post #818911 9th Mar 2020 4:02pm
Mike_E
United Kingdom 2015 Defender 90 Puma 2.2 HT Aintree Green
Excellent feedback. Thanks.
Post #818927 9th Mar 2020 5:36pm
2010Blackdefender90
Mine works well because I have a 2” lift, which allows all four wheels to stay planted on the ground. If you do lift a wheel with ATB’s, touching the brakes, with ABS, does restore drive to a spinning wheel.
Post #818928 9th Mar 2020 5:39pm
Page 2 of 2 <12
