Home > Puma (Tdci) > Weird noise.
Page 2 of 2 <12
RED-DOT wrote:
It goes away when clutch de-pressed and do you think LR will wear it as it is now 3 years old and out of warranty BUT i have done 15k gently and the first Defenders were fitted with a weak pressure plate?
How much for a new clutch from a LR outlet or an Indy?
Thanks.
No chance if it's out of warranty!
A new clutch from a dealer is about £770 parts and labour plus VAT, so approx £1k. Genuine clutch kit is about £250, an AP (Borg & Beck) clutch is about half that (and is probably made in the same factory). Kit in both cases includes driven plate and cover.
I am currently trying to decide whether to do it myself and have all the hassle that involves - and it is a very heavy gearbox - or pay the money and let LR do it.
Post #80954 19th Jul 2011 11:23am
AndrewS
You will need a new fly wheel as well I expect. ££££££££
The simple fix would be to PX it to the dealer let them sort it and you drive away with a new D4 er Defender Whistle 130's have feeling's as well you know Smile
Post #80972 19th Jul 2011 1:51pm
But at least the Puma flywheel should be cheaper than the awful dual-mass abomination needed on a TD5 every time the clutch is replaced!
Post #80973 19th Jul 2011 1:57pm
Allan
Australia 2008 Defender 110 Puma 2.4 SVX Station Wagon Santorini Black
I doubt the flywheel needs replacing as the main problem is the clutch plate springs. Only if they have let go and scorred the flywheel would it need replacing.
Allan
Post #80982 19th Jul 2011 3:14pm
AndrewS
Allan
Yea I know I am just winding Red Dot up Thumbs Up 130's have feeling's as well you know Smile
Post #81046 19th Jul 2011 8:16pm
RED-DOT
Goes in tomorrow and i have told Morrisons to do as required and charge me what they want and i will bend over provocatively when the bill is raised!!! NOT.
Getting a FL2 courtesy car so i may do the west-coast with the dogs.... 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #81070 19th Jul 2011 10:06pm
JSG
Good luck RD - at least a FL2 will be more satisfactory than an outdated Defender Thumbs Up John
2011 Tdci 110 CSW XS
Post #81110 19th Jul 2011 11:51pm
Allan
Good luck RD
Allan
Post #81116 20th Jul 2011 12:03am
RED-DOT
FL2 feels so soft and it rolls like feck and it is quick but not for me... im missing my brick already. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #81202 20th Jul 2011 5:03pm
JSG
Good for you - I knew you'd come round to the Def2 way of thinking Thumbs Up John
Post #81210 20th Jul 2011 5:42pm
Landyrob
United Kingdom 2012 Defender 110 Puma 2.2 HT Alpine White
my clutch has now 64000 km still the first one, does rattle a bit when you leave it in standstill but it's still running, gears still change perfectly.
Post #81239 20th Jul 2011 7:35pm
RED-DOT
Mine seems not to release 100% and get a bit of backlash on the props and makes a wee crack when in neutral when the pedal is pressed and released...
Dealer has a Grey Metallic (not sure if it is Stornaway) Utility XS with black chequer plate and Saw-tooth alloys and 235 BFG all-terrains and it looks mighty nice... just 33 reasons why it won't be mine. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #81266 20th Jul 2011 8:44pm
RED-DOT
LRCS, very helpful... dealer, not. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #81410 21st Jul 2011 2:12pm
RED-DOT
All sorted now, what a difference... turbine smooth changes and smooth start ups and shut downs. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #81628 23rd Jul 2011 12:01am
Page 2 of 2 <12
