![]() | Home > Technical > clutch pedal hit floor |
| Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582
Clutch less gear changes are a technique that would get you there, but unfortunately need a bit of practice, preferably in someone else’s car!
I learnt in Army Land Rovers and did not kill any gear boxes, though some may have had a few chipped teeth! 80" 1948 Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
| Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2378
Is it a Tdi ?
If the pedal is stuck down then it sounds likely that clutch fork pivot has worn through the clutch fork. Unfortunately it's a gearbox out or pushed back to replace it. HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
| dorsetsmith Member Since: 30 Oct 2011 Location: South West Posts: 4554 |
Not the fork then slave cylinder or master cylinder and no loss of dot 4
1. has clutch fluid been changed ? 2. colour of the fluid black or dark in colour seal braking down 3. master cylinder piston seal can fail but not loss fluid i.e. fluid is leching past piston seal and you pedal lost pressure 4. slave cylinder is gear box out job Last edited by dorsetsmith on 8th Jan 2020 10:06am. Edited 4 times in total |
| sjc501 Member Since: 05 Feb 2018 Location: Glasgow Posts: 148
Thanks for reply guys .Its a 2.2 ddci . I managed home by stopping and staring and crunching into 1st and 2nd but not ideal
| Rkcorry Member Since: 23 Jan 2017 Location: Northern Ireland Posts: 227 |
Dirty black fluid would indicate a breaking down of the inner seals on the clutch master cylinder, hopefully it is just this which is a simple enough fix, luckily it was in my case.
With the slave cylinder being concentric in a 6 speed gearbox, this will be slightly more awkward. |
| BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 924
Had the same thing on our 2.2 110 last year. Turned out the slave cylinder had died. Gearbox out job and did the clutch at the same time. Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
looks like i need a slave cylinder so doing clutch etc at same time .
Any suggestions for Clutch set up .I want to keep this 110 so want to put replace with good parts etc . Anyone heard about the synchro ultra spec clutch or any other upgrades ?
Thanks |
| Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357
lofclutches.com WARNING.
This post may contain sarcasm. |
| fatboyron Member Since: 28 Jul 2018 Location: Aylesham Canterbury Kent Posts: 116
same thing happened to mine but just before Christmas it was my slave cylinder so the gearbox have to come out to fix it so change the clutch for clutchfix set up and swap the gearbox output shaft for the version 2 at the same time
| Marks Landy Member Since: 09 Feb 2015 Location: Cheshire Posts: 306
Just out of interest..
How much did that cost? Was it around a days labour? |
£370 for the clutchfix kit
£100 for gearbox output shaft version 2 £520 for labour that includes they had the transfer box off because it had leak that was at my local garage |
Hi what's the clutch fix kit ? Excuse the ignorance . Gearbox shaft version 2 ? Is this an upgrade .I was going to get new clutch /flywheel from LOF as advised and slave cylinder etc .
Just found it on TMD site so another supplier of clutch set ups .
