Home > Maintenance & Modifications > Diff oil and swivel pin grease mixing
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
This thread refers:
https://www.defender2.net/forum/topic70611.html
So I'm trying to figure out all the parts that I will need to do this job. It's on a 2006/7 110 300Tdi
So looking at the attached picture, I will need the following:
7.FTC4785
8. FTC3276
11.FTC3276 (THE GASKET AT 11)
15.FRC2310
21.FTC3646 (THE GASKET AT 21)
22.FTC3648
23.FTC5268
24.STC3435
and a swivel pin seal an gasket LR059968 and FRC4206
Does this sound correct? Any input will be appreciated.
Post #809014 6th Jan 2020 3:14pm
oneten110
Looks about right. Personally I wouldn't bother with the paper gaskets, I would use a gasket sealant type stuff as manufactured by Elring.
http://www.wilmink.nl/Elring/Elring_vloeibare_pakkingen.pdf It is not a Defender, it is a One_Ten
Post #809361 8th Jan 2020 3:55pm
jfh
Thanks I appreciate your help.
This setup differs a lot with my old '84 model's setup.
I use the paper gaskets but I give it a very very thin coating of sealant on both sides.
Post #809362 8th Jan 2020 4:01pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
that dirko smoo is the business
Post #809368 8th Jan 2020 5:12pm
