![]() | Home > In Car Electronics > Help needed- central locking |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1138 ![]() ![]() ![]() |
1. Puma's alarm ECU connects orange and pink to 12V/ground or ground/12V to lock or unlock - I just don't know which way round. I guess you could just try with one door.
Personally I would first measure voltages between blue and green while activating lock and unlock, just to make sure. 2. There's only one switch in the Puma driver's door to signal the alarm ECU to lock/unlock if you push/pull the door knob on the inside. So two wires yellow+pink to ECU and black to ground are sufficient here. Again I don't know if the Puma switch is open or closed when the button is up. But you can easily measure resistance with a multimeter. Your aftermarket module seems to have one switch to lock and another one to unlock. I would expect the control module to lock if either brown or white is connected to black. Questions: locks when open or when closed (I expect on switch closed)? momentary or permanent (there are similar systems where you can connect a momentary on-on rocker switch for the dash)? Again I'd just try or measure your existing actuator module. Anyway, as your system seems to need two switches and the Puma door has only one, for safety I would not connect the driver's door switch at all (if your control module will work anyway). It's bad if you could only lock the doors from the inside but can't unlock them again in an emergency, where you don't want to fumble with the remote. Instead I would put an on-on switch in the dash where you can easily reach it. |
itolond Member Since: 16 Jan 2016 Location: Singapore Posts: 193 ![]() ![]() ![]() |
Appreciated- Yes agreed, after fumbling about it looks like a square peg in a round hole- best bet is momentary rocker switch to ground which hooks directly into the controller.
