![]() | Home > Puma (Tdci) > ..Correct engine oil.. |
| PCM Member Since: 25 Jan 2019 Location: North East Posts: 895
Mate.
At the top of the page there is a link to a whole list of correct engine oils. |
| Ecco Member Since: 31 Oct 2015 Location: Kuala Lumpur Posts: 280
I know, i know, my apology as i haven't explained, i went trough list, but i cant find anything listed there, in Malaysia. So i noticed, that, its mentioned it has to be C3 grade, and i did found this oil, i have posted pic for, so i just wanted some of gurus here, to confirm, is this okay to use or not..
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
I've no idea of the significance but my understanding is that it should be C1 rather than C3. Darren
| skidrov Member Since: 06 Oct 2013 Location: Melbourne Posts: 56
Do the Malaysia-spec cars have a DPF? In Australia, none were fitted with one - so wondering if perhaps Malaysia is the same (no reason it should be).
Reason for asking is that your oil choice is simpler if no DPF - you then choose the same oil as the 2.4. |
| Supacat Member Since: 16 Oct 2012 Location: West Yorkshire Posts: 11018
Have a look here if you need a little more info:
https://www.opieoils.co.uk/t-acea-car-engi...ained.aspx I have no idea of your engine spec, standard RoW or a market specific one? |
| fatboyron Member Since: 28 Jul 2018 Location: Aylesham Canterbury Kent Posts: 116
hello there this is what I use when I service mine it's designed for the ford transit engine so can't go wrong
https://rover.ebay.com/rover/0/0/0?mpre=ht...3729207396 |
| nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 720
I use a Millers 5W 30 synthetic, so i would suggest that you are perfectly ok with this.
..my truck has DPF..its 2.2 Turbodiesel Puma, MY2014 110 DC..its stock and nothing has been modified...based on what Supacat posted, it seems C3 is suitable for light trucks with DPF engines ?
| Julie Member Since: 07 Oct 2017 Location: La Réunion, Madagascar Posts: 589
I'd rather doubt that your car is conform to Euro 5 (is equipped with a DP)
If it was it wouldn't work with Malaysian diesel It seems that Malaysian diesel currently complies to Euro 2. https://paultan.org/2014/11/17/malaysia-ge...a-mohamed/ Your engine is a ROW type Get this clarified with Land Rover Malaysia |
@Julie
..i came back just now, from JLR Service center here in KL...and yes, it turns out that you are correct..trucks sold here do not have DPF installed...only imports(2nd hand), which came in to country trough non JLR , does have DPF, they told me this. Thank you for an insight. |
| All times are GMT |
