Home > Maintenance & Modifications > Defender Genuine XS side step refurb.
Marky5522
United Kingdom 2015 Defender 110 Puma 2.2 XS DCPU Corris Grey
Genuine XS side step refurb and rebuild. My side steps were looking a little tatty I stripped them down had them blasted and powder coated including the Tread plate and rebuilt them using stainless rivnuts and hardware. Finally treated the inside with dinitrol before refitting the end caps and re installing. Here are a few pics.
Post #806766 18th Dec 2019 4:38pm
nidge n
Thats a great job, did you renew the rubber or was it original? I ask because the rubber on mine is damaged and i dont want to replace the whole step if it can be repaired. Good job Thumbs Up
Post #806793 18th Dec 2019 7:25pm
Marky5522
Original rubbers because they were in great condition for a 4 year old defender part 😂. Not sure if the rubber can be purchased separate, I hear the rivets can be bought separate but I choose the rivnuts as it means the treadplate can be removed quickly if it needs recoating when it wears.
Post #806809 18th Dec 2019 8:54pm
Re: Defender Genuine XS side step refurb.
Marky5522 wrote:
These look good, can I ask where you got them from?
Post #806873 19th Dec 2019 2:33pm
Marky5522
The threaded rod is just a 45mm stainless steel grub/set screw (was going to cut a stainless threaded rod into lengths but was feeling lazy so ordered them instead) The other part is sometimes referred to as a barrel nut or furniture nut. I got them locally but all available from eBay
Post #806883 19th Dec 2019 3:23pm
doublecabjon
They look excellent, and are sure to last a bit longer. Did you say they were 4 years old?!
Post #808577 3rd Jan 2020 11:49am
Marky5522
Yea Nov 2014. The truck had been done with Dinitrol when new And done 29k so they weren’t to bad but had corrosion about the usual stone chip areas.
Post #808583 3rd Jan 2020 12:17pm
Pickles
I'm a big fan of the factory side steps,.....TOP job.
Pickles.
Post #808644 3rd Jan 2020 10:12pm
discomog
A lovely job and the refurb is sure to last longer than the originals. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #808682 4th Jan 2020 10:04am
andycam82
Northern Ireland 2014 Defender 110 Puma 2.2 XS CSW Santorini Black
Look great! Smile
I’ve just picked up a 2014 SW and the side steps need tidying too.
Whereabouts in NI did you get them blasted and powder coated mate?
Andy
Post #813995 6th Feb 2020 11:09pm
Marky5522
Powdertek up towards Belfast Docks. Speak to Chris and he will get them blasted and coated. I stripped them myself and dropped them off with him. He’s seen more of my defender parts than the Landrover factory 😂. Mention Mark with the defender and horsebox sent you.
Post #813997 6th Feb 2020 11:19pm
andycam82
Thank you and will be sure to mention you Very Happy
Post #813999 6th Feb 2020 11:30pm
isacs
I’d put heli tape on the exposed areas to safe guard the hard work
Post #814006 7th Feb 2020 12:55am
andycam82
Actually on reflection, would it be worth galvanising the steps after they were shot blast? Would prefer them to last a good while if I can.
Any tips on how to tidy up after they’ve been hot dipped?
Also anyone recommend a place in NI to get them hot dipped?
Post #814041 7th Feb 2020 2:31pm
Marky5522
I did consider galvanising but if you pop out an end cap and look at the wall thickness I really don’t think they would come out of the dip tank the same shape they went in 😂. Somone on this form I think was selling a set that was galvanised so I guess it’s possible. NK Coatings in NI could do it but bear in mind between galvanising and powdercoating cost you would be able to buy 2 new sets of steps. I have helli tape on the rear area to protect from debris thrown from tyres and the front is protected by the relocation of the mud flaps with the Gwyn Lewis kit. Lots of options out their for steps but I like genuine Landrover although the cost often makes me gulp 😓
Post #814063 7th Feb 2020 6:22pm
