Home > Td5 > Rust hole in door frame. How bad?
MC84
United Kingdom 2001 Defender 90 Td5 HT Chawton White
How bad is this. Its worse on the near side but the off side is going the same way. The drain holes were blocked which has led to this.
Is this area double skinned? I expect this is just the tip of the old iceberg! Has anyone sorted this problem and has pics?
It is the lowest part of the bulkhead. The pic is of the lower front hinge.
Thanks in advance and Happy New Year, Mike
 Mike
Hard Top 90 TD5 2001
Ford 100e 1959
www.youtube.com/mikemakesit
Post #808127 30th Dec 2019 9:17pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
That's a hole in the lower part of the bulkhead, probably reparable with after market parts Sad Just because you're offended doesn't mean you're right.
Post #808131 30th Dec 2019 9:23pm
grafty99
Within 30cm of a body mounting so probably an MOT failure. Definitely repairable though Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #808137 30th Dec 2019 9:29pm
roel
It is repairable but I would check the whole bulkhead as it will probably be rusty on other parts too. Like below the the window frame and in the window hinge area. Roel
2003 90 Td5 (2009-now)
Post #808218 31st Dec 2019 12:37pm
Silvertoolbox
Just doing mine just now. MOT time and out comes the welder....
Started out as lower part of footwell (helpfully a double panel and rust trap - thank you, Land-Rover).
Also top / front of door pillar. So much easier with door and wing off (once you get them off!)
As noted above, it will offend MOT tester, even if it's only cosmetic. There is a thicker plate behind it so cut with care.
Happy welding. Ex scottish & southern 110 Td5 van (shed) with PTO driven winch (L-R special vehicles)
Before that, Disco 1, Freelander 1, 26105382 80" with a 1600cc (not much slower)
Post #808771 4th Jan 2020 11:04pm
MC84
Thanks for the input guys.
Silvertoolbox, I thought it would be a doors and wings off and did wonder if it was a double skin. I have previously repaired both sides inside the cab where the door light switches are. Guess I'll move outside now.
Is anyone aware are repair pieces/panels for the bulk head or is it make what you need as you go?
Thanks again. Thumbs Up Thumbs Up Mike
Ford 100e 1959
Post #809016 6th Jan 2020 3:33pm
Silvertoolbox
Hi Mike,
Might be worth investing in new hinge and wing fixings, not dear and as yours is also getting on a bit, likely to be casualties...none of mine will go back although 50% useable.
AM605061 bolt for wing rear edge
AK616011 nut
BYG100140L bolt for door hinge?
ASR1459 nut
Sets of both available on e-bay.
Above Parts for 1A model year (2000-2001)
Yep, courtesy light switch hole needs reducing back to original size too.
Homemade repair panels, for extra "enjoyment"! Ex scottish & southern 110 Td5 van (shed) with PTO driven winch (L-R special vehicles)
Post #809078 6th Jan 2020 8:59pm
MC84
Great and thanks for the info. Are there any repair panel bits or do I make them as I go?
Thanks again Thumbs Up Thumbs Up Mike
Ford 100e 1959
Post #809085 6th Jan 2020 9:25pm
MC84
I can see there are some bits available. I'll continue looking and go from there. Thumbs Up Mike
Ford 100e 1959
Post #809098 6th Jan 2020 9:51pm
MC84
Are these them?
I think these are the parts that would help me. Can anyone concur?
Also, am I butt welding these as they don't seem to be crimped in at all. I think I would want to tweak them in and lap weld.
https://www.ebay.co.uk/itm/1-PAIR-BULKHEAD...0005.m1851 Mike
Ford 100e 1959
Post #809629 9th Jan 2020 10:20pm
