Home > Off Topic > Wiring Question Cobra
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Following my other post I'm hopeful some kind sole (Martin Thumbs Up ) will help me answer a few electrical questions / queries as this is officially the most helpful forum ever.
For the Engine section of the loom instructions shown:
1)Tacho (White/Black 1mm) - Does this goes to the Coil or to the Alternator? Do I need to run a wire then from the coil to alternator?
2)Starter Trigger (Red 2mm) - Does this go to the starter motor?
3)Ignition Switch Feed [coil +VE] (White 1mm) - Am I right that this goes to the coil?
4)Charge Warning Light (Brown /Yellow 1mm) - Am I right this goes to the ignition lamp connector on the alternator?
Thanks for your help.
Post #808111 30th Dec 2019 8:39pm
