![]() | Home > Maintenance & Modifications > Wheel carrier height |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2257 ![]() ![]() ![]() |
Not mine but there are some pix is this for sale thread that may help on location of hitch??
https://www.defender2.net/forum/topic70338.html?highlight=penman |
Whirly90 Member Since: 01 Sep 2016 Location: Ampshire Posts: 410 ![]() ![]() ![]() |
That hitch is on the crossmember, which is where I want to mount mine to straighten the angle of the trailer, it’s the wheel that’ll need moving.
Avelingporter Member Since: 25 Jan 2016 Location: Southampton Posts: 407 ![]() ![]() ![]() |
I have a receiver hitch for my nato hitch. I use a drop plate mounted upside down so it raises the hitch. The hitch is then at the correct height mid crossmember. My wheel carrier is a Mantec one. Tyre clears the hitch but needs a bit of a wiggle to open the hitch.
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
Partially open the spare wheel carrier when hitching up? or modify your current wheel carrier with a riser plate so it holds the wheel slightly higher.
safari equip wheel carrier for your viewing pleasure. ![]() Click image to enlarge 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
I also have the Safari Equipment wheel carrier and I'm able to tow my Sankey Narrowtrack trailer without an excessive nose-down stance or issues with the spare wheel. I have a Dixon-Bate adjustable carrier mounted on a NAS step, which itself has lower hitch bolt-holes than the crossmember, but then use the adjustment to raise the NATO hitch to an acceptable height for the trailer.
The 1st photo shows the result when the 110 had a 2" suspension lift. That has since been removed, but to compensate the hitch slider now sits in the top position. There is ~2" clearance between the bottom of the spare tyre and the top of the hitch carrier. The trailer sits with a slight nose-down stance and is very stable to tow. ![]() Click image to enlarge ![]() Click image to enlarge |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 727 ![]() ![]() ![]() |
If it helps, I have a Britpart spare wheel carrier, a 285 75 r16 spare wheel and a NATO hitch mounted on the rear crossmember. To tow the Sankey I have to remove the spare wheel as the jaw won't open and when not towing the trailer, the hitch has to be inverted to prevent it hitting the underside of the spare tyre which in turn prevents the rear door closing fully. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top 1992 200Tdi 90 Truck cab with Land Cruiser axles |
foxhound Member Since: 02 Mar 2013 Location: United Kingdom Posts: 363 ![]() ![]() ![]() |
I'm pretty certain that the penman is intended to be towed with nose down for stability. The hitch is 'higher' on a penman than on a sankey w/t trailer so will be more nose down than a sankey when hitched anyway.
the Army don't use dixon bate drop plates, the pintle is on the cross member itself so the penman hitch sits higher (and the spare wheel is on the LR wolf passenger side). On my 110, to have clearance to open the pintle jaw (for both sankey and penman), I took the plate with the 3 spare wheel pins off my carrier frame and rewelded it 2 or 3 inches higher. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3410 ![]() ![]() |
swap you're rear wheel carrier for one of these, raises the height by a few inches.
I carry a 35 inch wheel on mine and can still attach the sankey trailer to the nato hitch fitted to the rear cross member: https://www.ebay.co.uk/itm/Land-Rover-Defe...Swu4BVt9Du |
Does this take the weight off the door hinges - it looks like a plate fitted direct to the back door but i might be missing something. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
It looks like that bolts to the back door, i'd rather have the wheel on a chassis mounted carrier. If i can't find a carrier that holds the wheel higher then i think it would be a simple enough job to fit that to my current carrier. |
The carrier I.posted the link to is a straight replacement for the standard fit bracket. It's been fitted for 5 years now with no issue carrying 35 inch tyres....
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3853 ![]() ![]() |
I found over summer that Taking off the rear wheel was so much easier than phaffing with a limited gap between opening the nato and the tyre,
Unless I backed up absoloutle straight it's a pain. I'm interested in the wheel holder that hold slightly higher, Could you post oa picture and iff possible measure how much higher it would raise the wheel? ![]() Click image to enlarge |
