![]() | Home > Maintenance & Modifications > Range Rover Sport Seats in my DCPU |
Looks good
![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2231 ![]() ![]() ![]() |
Thanks!
Erm not great ![]() ![]() |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
What’s the seating angle and leg room like please?! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
Next mod Roy5695
![]() 2008 SVX 90 2000 XS TD5 90 |
Leg room is good, better than 60/40 bench seats anyway. Angle is decent, not uncomfortable but not mega comfy either. Id say similar if not the same as TDCi seats. That said doing this kind of mod you can set your own angle. I just wiggled around until I found a happy middle. Marked them and welded them in position. |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1249 ![]() ![]() ![]() |
I've got L322 seats (they're better than sport seats right
![]() Now I've fitted them and proven the system works I'm more inclined to chop into the wheel arches and drop them down an inch or two which will make them quite a bit more comfortable. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
I did also consider L322 seats as well, my dad wasnt impressed when I asked if I could borrow his for measuring
![]() Got some pics? Would love to see it. |
Not got any decent ones of the back seats at the moment.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Impressed with the fronts! Would have thought theyd be way too big.
Got to see the rears!! |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
Nice work chaps. WARNING.
This post may contain sarcasm. |
Ask and ye shall receive courtesy of a special trip out to the stable workshops so apologies about the dark.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge The frame was designed so that there's no uprights in the middle of the box which means that I can put long items in under the seats. Not sure they'd fit into a double cab as you can see by mine they go half way through the "rear windows". One of the reasons behind finally converting to a utility wagon top (had the Series panels sat around for ages). The L322 seats normally latch into brackets on the wheel arches so you need to fabricate something for those. Similarly there are latches in the floor which trigger the seat belts to be released so those need to be fabricated. I've also got a chopped off loom off a BMW M5 on the way which should mean I can get easy access to the other pins on the front seats so I can build up a PWM controller for the heated seats. Have had the motors working for ages. I might once I get another vehicle on the road, so this isn't my only one, build a custom seat box to drop the front of the front seats down a little bit and reinstate the motor on those which I removed to make them a bit more comfortable. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
Forgot to apologise - dogs and I were at a shoot today so Land Rover is a little muddier than normal. Actually who am I kidding, it's always like that!
![]() Bonus of leather means easy to wipe down. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
That looks bloody good. Nice job!
I can just about see through the dirt ![]() These seats would be perfect in a regular CSW take full advantage of them |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8406 ![]() ![]() ![]() |
I'd rather have the labs! Cheers
