![]() | Home > Tdi > heating upgrade for free |
sonoronos Member Since: 30 Aug 2011 Location: USA Posts: 8 ![]() |
right!
if you have an opportunity, you should try it with the lower dash removed altogether! |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125 ![]() ![]() ![]() |
thanks I will try this tomorrow
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 ![]() |
went for a drive today, only about 10 miles, and it has turned a tad milder, but I had to turn the fan down, and open the window, a bit too warm.
AndyT1973 Member Since: 06 Nov 2017 Location: Portsmouth Posts: 5 ![]() ![]() |
I took mine off and swapped them over to other side (upside down). Now that actually clear the side windows (ish).
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
WOW ANDYT, that's a tip I've never heard before!
![]() Also, open your bonnet and reach under the heater air intake and remove the rubber bung altogether and tip a boiling kettle of water in the wing top grill to wash it out, that way water can't sit in there when it's blocked with mulch and it can reduce steaming up, as damp air will not be sucked in from the heater. QRZ M8VPF |
thompjas Member Since: 07 Mar 2014 Location: Northants Posts: 36 ![]() ![]() |
in the past, I had the transfer box/gearbox tunnel removed whilst investigating a noise - you'll be surprised by the heat that comes into the cab !
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 790 ![]() |
And the noise!
