Home > Tdi > 300 tdi glow plug light.
spudfan
Ireland
300 tdi. The glow plug warning light does not come on when the key is turned up to the starting position. All of the other lights come on as they should. I have changed the dash bulb but still no joy. It starts fine. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #807001 20th Dec 2019 12:43pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
1. With the help of somebody chech for power at the glow plugs them selves with a multimeter.
2. If no power check fuses and relay.
3. If you have power at the glow plugs it's the wiring going to the dash.
Post #807003 20th Dec 2019 2:03pm
spudfan
Ireland
Thank you Thumbs Up 1982 88" 2.25 diesel
Post #807032 20th Dec 2019 5:05pm
spudfan
Ireland
Had a look and there is no wire going to the bulb holder in the warning panel. That probably explains it. 1982 88" 2.25 diesel
Post #807046 20th Dec 2019 6:58pm
jfh
Post #807051 20th Dec 2019 7:15pm
spudfan
Ireland
Is it possible to reconnect the wires to the bulb holder on the glow plug bulb? 1982 88" 2.25 diesel
Post #807270 22nd Dec 2019 9:42pm
jfh
I haven't tried it before on those bulb holders, but you will have to remove the contract strip, feed the wire through, solder it on and pull the wire with the contract strip back into the holder.
The difficulty part si figuring out how to remove that contact strip.
Post #807289 23rd Dec 2019 5:40am
spudfan
Ireland
Thank you. I was not going to try it myself but to ask the garage to do it when the vehicle is in for other work. I just hold the key for about 10 seconds and she fires up grand. Thanks again. Thumbs Up 1982 88" 2.25 diesel
Post #807313 23rd Dec 2019 11:39am
