Home > Maintenance & Modifications > Hard top to windows
Likeomg
Hard top to windows
Fancying converting from a van to windows... just really prefer the look
no chairs or anything;
I've been given a price for sides, windows and seals about 900 does that sound right? (used obviously)
Anything else ill need apart from interior trim? Seals to the roof / tub?
Thanks.
Post #806974 20th Dec 2019 12:36am
Co1
Could you not just get the jigsaw out and cut the windows into your existing sides? Perhaps there isn’t enough structural integrity if you do this?
Post #806976 20th Dec 2019 6:46am
topless_matt
England 2007 Defender 90 Puma 2.4 HT Tonga Green
You can buy the window kits to fit your hard top. Just a case of measuring many times before you cut!
Substantially cheaper than 900 Hold my beer and watch this!
Post #806980 20th Dec 2019 7:31am
V8GPC
Edd China did it in a wheeler dealers episode
Post #806981 20th Dec 2019 7:43am
If you don't want rear seats, you might want to consider fixed glass instead of sliding windows - all the visual benefits without the drafts, rattling and corroding catches. Darren
Post #806985 20th Dec 2019 8:53am
Sulisuli
VGS would be the company to contact Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #806992 20th Dec 2019 10:32am
ppad
United Kingdom 2005 Defender 90 Td5 HT Caledonian Blue
More than 5 years ago now I bought a van and had it converted from no windows to windows - it was off to Switzerland with me so side windows were essential to see the traffic at junctions.
And it has turned out brilliant back in UK also. Would absolutely recommend.
Also I added side facing dicky seats for the grandkids on short journeys. Also brilliant. All reinforced underneath and for a 15kg object at 30mph as sound as any other restraint, calculations done.
Insurance hasn't really been a bother, lots of time on the phone initially getting them to accept the mods, then routine renewals ... except that the company bless 'em keeps changing the category from car to van and back again. But all good and 5-6 years down the track the windows are still 100% sound and waterproof.
Gumtree4x4 did the work for me as it was close to Gatwick and good the the Swiss commute, not real close for you tho Smile Sold the much modified 110 2.8, in Oz
Brought the 90 home from Switzerland ...
Post #807004 20th Dec 2019 2:13pm
Likeomg
Hmm
I’m really against the cutting method and would rather just put them into storage as genuine good condition panels for the future if need ever arises...
I too would like the blind spot visibility as so many times it’s awkward.
I take it isn’t too much of a massive job?
Post #807118 21st Dec 2019 12:21am
Mo Murphy
It's a straightforward day long nuts and bolts job to change the hardtop sides if you are just swapping them.
A couple of extra pairs of hands would be essential.
I would recommend new seals whilst you are about it.
HTH
50 Shades of Pennine Grey
Post #807126 21st Dec 2019 8:53am
sako243
One thing to consider possibly is "security".
I went the opposite way (well on a 110 from a CSW to USW) for two main reasons. The first being that I've got a set of L322 seats fitted in mine which meant that the rear seats needed a latch fabricated to hold the backs in place, the latch was halfway through the rear windows. Changing to van sides from a Series vehicle meant I could do this easily and look half decent. The other reason was that I do a lot of shooting and with windows in the back (and no load-space cover like most vehicles) then everything is on display. I also tinted the rear window quite heavily (can't see out of it anyway with the L322 seats as they are) so now I've got an enclosed boot space that nosy people can't see in to.
But being a 110 I've still got the second row doors for extra visibility at junctions. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #807132 21st Dec 2019 9:46am
Likeomg
I've managed to purchase a set of genuine 90 panels with glass / seals from a 16 plate car...
Is it as simple as it sounds? does the roof need to come off or can you just support the weight of it?
bit of a project on my hands, I rarely leave anything value in the back of the truck only thing is i need to relocate hte Hertz HDp1 and HDP4 amps that where mounted on the van panels...
Maybe build something like this? I have a Hertz 380D - 15" sub in the rear amps either side sub in the middle? Shocked
Post #810954 19th Jan 2020 11:10am
Likeomg
Oops didn't attach
like this
Post #810957 19th Jan 2020 11:42am
oneten110
Leaks, don't forget the additional leak potential It is not a Defender, it is a One_Ten
Post #810980 19th Jan 2020 1:40pm
oneten110
There is no need to remove the roof, if you have something to support the weight of the roof panel whilst you remove the sides.
Have done it several times on both 110 hardtop and 110 CSW It is not a Defender, it is a One_Ten
Post #810981 19th Jan 2020 1:42pm
Likeomg
Hopefully it won’t b too bad, the car is garaged most of its life and does 3k miles a year
Post #810983 19th Jan 2020 2:04pm
