Home > Maintenance & Modifications > Sqeaky brakes (again) and any upgrades on Brake worth it?
Stacey007
Since owning my Puma now over 4 years Its had some brakes and pads in my ownership.
Its also had a couple of calipers replaced.
Recently its started squeaking, more so first think in the morning and genrally goes away but noticed its coming back a bit more..
Currently I have cross drilled Terafarma? front discs with Mintex 128-FD?
Can I upgrade, change anything else to makes them slightly better? (and not squeak)
Is it worth upgrading the brake pipes? or the calipers? without going for the Big brake conversion ?
Any recomendations appreciated
Thumbs Up
Post #806761 18th Dec 2019 4:13pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Watching this with interest, as my dealer commented last week on the service the discs all round are starting to lip but servicable for the next 10k.
Rather know which why to go than make a panic decision when forced. 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #806768 18th Dec 2019 4:52pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Likewise mine likes an occasional squeak first thing. I’ve always put it down to wet/damp brakes.
On a related topic the family wagon (Discovery Sport) is due its first MOT in a few months time. One of the rear disks has rust on it that has worn away a line in the pad. It does not impact its braking as far as I can tell. Im assuming that’s will be an MOT fail??? Any thoughts?
Post #806770 18th Dec 2019 5:04pm
landy andy
Only thing that has ever stopped Defender brakes squealing for me has been original Land Rover pads. That’s why I will only fit them now.
Post #806782 18th Dec 2019 6:48pm
topless_matt
England 2007 Defender 90 Puma 2.4 HT Tonga Green
I use EBC green stuff pads, absolutely great stopping power. Smooth progression and not snatchy.
I also have grooved discs, had drilled vented ones but had one shatter once during heave braking with trailer on the back, ripped off calliper in the process and chewed a boost alloy too!
Grooved ones have been fantastic so far. Hold my beer and watch this!
Post #806789 18th Dec 2019 7:16pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
as discs wear they can create a radius on the edge of the disc. This can cause it to squeak.
Post #806799 18th Dec 2019 7:50pm
oneten110
Land Rover very thoughtfully have the minimum allowable thickness of the disc, either stamped into the rim of the disc or cast into the central, unwiped, part of the disc It is not a Defender, it is a One_Ten
Post #806801 18th Dec 2019 8:06pm
htb2
Wales
Never been able to read them as writing normally rusted over, too much road salt up here. You know disc is too thin when you hit it with a hammer and it falls off the hub whilst still bolted on. Very Happy
Post #806802 18th Dec 2019 8:11pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
There’s a few new options due shortly from a well known supplier I believe after Xmas
Waiting to get my new ones fitted 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #806803 18th Dec 2019 8:26pm
bankz5152
Brembo pads + Mintex anti squeel compound. Never had a squeek or squeel.
Slotted discs are worth it if you drive hard/tow otherwise not. Drilled can crack and get damaged off road.
Post #806814 18th Dec 2019 10:09pm
oneten110
The amount of wear allowed is surprisingly little.
I fitted a new pair of discs (rear) a couple of months ago and a new disc is 14mm thick. The wear limit is 13mm so basically the discs should be changed pretty much every time you change the pads. It is not a Defender, it is a One_Ten
Post #806854 19th Dec 2019 10:42am
L110CDL
I have drilled/grooved vented front disc's which i have green stuff pads in and they don't squeak and i have drilled/grooved disc's in the back with Mintex pads and they don't squeak and at her next service the back disc's will be changed, disc's and pads and with be putting in Terrafarma pads that are equal to the green stuff pads as they don't do them for the back Very Happy
I don't know of hand which make of disc's i have on Millie Rolling Eyes Clayton.
Keeper.
Post #806954 19th Dec 2019 9:29pm
Stacey007
I've just gone through some invoices
Looks like I have Terrafirma discs (front) sloted and vented with Mintex pads...
The rears although are fairly new have not found yet and its from the back the squeak is coming from Smile
Post #807013 20th Dec 2019 3:22pm
Fatbaron
When I bought new discs all round, the lads at Devon 4X4 recommended not to go with drilled or grooved as they just fill with mud when off roading. Copper slip on the rear of the pads and I never have squeaking.
Post #807127 21st Dec 2019 9:23am
