Home > Puma (Tdci) > One wiper not working
Zed
When driving today my left hand wiper started sweeping too far down and then after a bit stopped completely. Right hand side is fine.
Any ideas? WARNING.
Post #806779 18th Dec 2019 5:12pm
gcc130
Just had similar with my drivers wiper.
Dashboard had to come out to find the gear was stripped in the wiper gearbox.
Best to change both gearboxes and flexi drive while you’re in there, and possibly the park switch.
Post #806783 18th Dec 2019 6:01pm
Zed
Censored . I feared as much. WARNING.
Post #806786 18th Dec 2019 6:06pm
You could try lubing down the spindle for the time being, it could be binding due to corrosion and adding to it.
Beyond that though, it'll be wiper wheel boxes out and drive. Rolling Eyes
You'd need new wiper arms and likely a puller too as well, as the wiper arms are a press fit on a splined spindle on the Puma.
At least, most of the parts are worth replacing at once is advisable. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #806791 18th Dec 2019 6:20pm
Clemmo
Zed...
you will have only used one third of the teeth on your wiper boxes.
Mark the position before you take apart.
Rotate through 180 degrees and you are on new teeth.
I did this a month back and all is/was good.
( I renewed the drive cable too)
Hope this helps
Clemmo Thumbs Up
Post #806795 18th Dec 2019 6:32pm
gcc130
Why do you need new wiper arms?
I’ve removed puma wiper arms several times without a puller and refitted them.
Post #806800 18th Dec 2019 6:52pm
Phil VM2.5
Belgium 2012 Defender 110 Puma 2.2 SW Keswick Green
Hi,
I also have a problem with it.
Is there info to how take the dashbord of ?
Thanks
Philippe current : defender 110 sw 2.2 puma 2012 and 230.000km today and
again my Range Rover VM2.5 engine from 1992 and 528.000km today.
One ten 1988 to 1992
1987 BMW GS80
One Ten from 1984 to 1987
One Ten from 1983 to 1984
Serie 3 109 from 1980 to 1983
from 1974 Jeep CJ3B and CJ6
Post #806913 19th Dec 2019 5:07pm
Clemmo
You don’t have to remove the Dashboard....purely loosen it.
Get the smaller screws below knee level..both sides.
Then undo the bigger Phillips type screws, including the grab handle and the radio/centre console.
I’ve found rather than struggle.... take the steering wheel off, remove the light/indicator Plastic supports and release the instrument panel too.
The more you loosen the easier it becomes.
It’s a fiddle..but not difficult
Clemmo Thumbs Up
Post #806925 19th Dec 2019 6:05pm
driver
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
dash out for wiper spindle replacement
Just done this job on mine, here are a few pics of whats needed basically you have to get it back to the bulkhead to get to the wiper boxes,
Didn't remove dash completely but moved it well out of the way, you will also need to remove all the heater pipes as well,
I removed the wiper motor, drive cable and two spindles as a unit then stripped, cleaned everything.
It took me a whole day to complete this including taking loads of pics for reference.[/code]
Post #806933 19th Dec 2019 7:14pm
Great pics there. Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #806934 19th Dec 2019 7:19pm
driver
Thanks Very Happy
Post #806936 19th Dec 2019 7:21pm
driver
Here is a couple more, I used these for reference for cable routing.
Post #806937 19th Dec 2019 7:27pm
Zed
Thanks for all the replies gentlemen. I will give it a go in between eating mince pies. WARNING.
Post #807153 21st Dec 2019 12:50pm
