Home > Puma (Tdci) > Front washer jet
Page 3 of 3 <123
I got mine done today.
As expected the Scrivets. (Plastic rivets) were the biggest pain.
All of them except for one all spun around, although I’m not bothered as according to the WSM they are basically a throw away part.
I managed to pry up the centre screw with a sharp small flat blade screwdriver.
Then remove that out with a trim tool. (Pictured with red handle).
Then the same procedure with the Scrivet body.
Such a pain they were and took 3x more than the job of changing the washer jet it’s self.
I cleaned the mating surface on the exterior bulkhead with the old jet off. Took the opportunity to Dinitrol though the hole and around in that area too.
A deep 13mm socket hand tightened on the extension bar only done the job. Not tightened as such.
I don’t have any issue tightening up from inside, as the jet didn’t move or slip. Probably because I cleaned and dried the misting surface.
The nozzles on mine needing adjusting anyway, and the jet spray is improved on mine.
I’m sure the Optimil is great but it should be for that price.
 ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #806655 17th Dec 2019 7:27pm
That is with the rear Head Unit support removed. You can see the washer jet rear with the brass nut in the back there. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #806656 17th Dec 2019 7:29pm
It's fiddly but easier than removing the dash! Good job done.
Post #806661 17th Dec 2019 8:18pm
👍🏻 Certainly is. That trim tool certainly helped get them out easier.
Can’t complain at 10 years plus life from the last jet. I did the rear one a year or two ago.
I might try the Optimil one day, but for now I’m happy enough. Very Happy ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #806666 17th Dec 2019 8:36pm
Roy5695
If you’re going to get a billet nozzle. Get the CSI fan jet nozzle. Bloody brilliant. And with a bit of a tweak to the feed pipe, wiring and pump it’s absolutely incredible. I get a fine mist over the whole screen, wing mirror backs, roof rack 😂 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #806822 18th Dec 2019 11:10pm
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #806823 18th Dec 2019 11:16pm
Page 3 of 3 <123
