![]() | Home > Puma (Tdci) > Yet another issue....... |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 ![]() ![]() ![]() |
is it warm or cold ? maf sensor worth a look give it a clean if since service it may be something to do with that
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17787 ![]() ![]() ![]() |
Volume control valve.
Markez79 Member Since: 27 Jun 2018 Location: South West Posts: 201 ![]() |
Happens when car is cold and warm..... ![]() |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
As Blackwolf has already said, vcv valve seems the likely suspect.
Many thanks as ever guys.
Expensive to replace? Mark |
have look below
https://bellautoservices.co.uk/bas2rrc-hel...4tdci/vcv/ part no LR009837 https://bellautoservices.co.uk/store/defen...our-valve/ ![]() Click image to enlarge Last edited by dorsetsmith on 17th Dec 2019 1:42pm. Edited 2 times in total |
Many thanks
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1317 ![]() ![]() ![]() |
You can get Denso branded for about £60 and unbranded for about £30 You can change yourself - only issue is awkward to access the bolts - there is full thread on here with pics on how to do it and the tool - ratchet wrench with extensions/universal joint |
Def Junkie Member Since: 30 Dec 2013 Location: Somewhere in Paradise Posts: 79 ![]() |
Hi Mark, was wondering if you've managed to fix the issue described here? I am struggling with the exact same issue. Tim |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 432 ![]() ![]() ![]() |
You need to have this response as an autoreply really. ![]() |
I do!
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20841 ![]() ![]() |
That’s usually because most of the time Blackwolf is right.
![]() ___\⭐️Lone|Star|State/___ ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
So I've had the VCV replaced (Denzo) but the problem persists. ![]() It suddenly loses power (when accelerating hard), does not respond to the accelerator, coasts along and then dies. Any help much appreciated ![]() |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2669 ![]() ![]() ![]() |
Hmmm, could be a dirty fuel pickup in the tank?
Time to drop the tank and inspect it - there could be crud around the fuel pickup, and when you put foot, the increased fuel flow is compromised by the blockage. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
