![]() | Home > Technical > Exploded diagram of the gear change on a 2015 defender |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3357 ![]() ![]() ![]() |
https://www.lrworkshop.com/diagrams/land-r...ange_45150 WARNING.
This post may contain sarcasm. |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4807 ![]() ![]() ![]() |
![]() ![]() 2008 SVX 90 2000 XS TD5 90 |
Guess I’m going to have to buy Part 1
I didn't look at that diagram properly before posting.
Do you mean the selector cup? https://www.onlinegearboxparts.com/product...nylon-cup/ WARNING. This post may contain sarcasm. |
No unfortunately, there is a rubber gaitor that has spilt on the selector assembly. 2015 HT XS 90
I think I know the part you mean but can't remember it's name. Dorset will no doubt be along in a mo to give the correct info. Leave it to the professionals an' all that! WARNING.
If it's a clean split, try superglue before buying an expensive complete assembly. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
witch rubber grommet
![]() ![]() Click image to enlarge 6- ULN50020 7- TSF 50030 8- TSF50020 !6- LR052893 |
It’s to badly damaged Darren so think I am going to have to purchase Part 1 as per Dorsetsmiths diagram below? 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
I know the part you mean and you are correct that it is piece of the Part no: #1 on the diagram and NOT sold separately.
(Rubber gaiter above the selector ball, over the selector shaft but retained under the whole selector assembly.) Mine wanted changing ideally too but not easily obtained, if you go to a breakers or eBay that's all very well but it won't be a new part either. Very annoying issue really as it's a single part. I tried tracking one down, but was categorically told that it wasn't available as a part on its own. ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Steve your a gent Thankyou for the explanation
Pic of this grommet
![]() you need grommet on the lower ball will investigate |
Dorsetsmith
