Home > Td5 > Courtesy Interior Lights Issue
thefender
United Kingdom 1999 Defender 110 Td5 CSW Barolo Black
Theres tons of stuff on searches, but can't find anything that comes to a resolution - so if you have any ideas please help..
99 TD5 County - Alarm works fine on doors and sensors - courtesy lights work fine using their respective slider switches. However, they will not come on when you open the doors. If the alarm is switched on and you open the doors, alarm goes off and very briefly the interior lights flash on and then off once so clearly some sort of communication is working to the alarm box of tricks and the door switches are working?. Anyone come across a resolution please?
Post #805505 9th Dec 2019 8:10pm
excossack
Long shot, but do the contact for the door switches need a clean i,e bad earth/bad connection? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #805508 9th Dec 2019 8:17pm
thefender
Hi thanks - I suppose thats possible but it would be all of them, plus the alarm works perfectly so I'm thinking the switches must be fine as that works when I open any of the doors (I have not checked the bonnet but I don't think that has an interior light function anyway)
Post #805512 9th Dec 2019 8:22pm
grafty99
My bet would be that they're turned off on the 10AS Thumbs Up
The factory alarm controls the courtosey lights, they can be configured a few different ways. One of the settings is permanent off apart from manual switching Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #805513 9th Dec 2019 8:23pm
thefender
Ah is that possible - How would I check or turn it back on - some sort of nanocom, mine only has couple of wires going to OBD so assumed mine doesnt have much functionality there?
Post #805514 9th Dec 2019 8:25pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Is the dome switch turned off? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #805516 9th Dec 2019 8:29pm
thefender
Not sure what a dome switch is but if thats the on off and auto switch on the light fittings then yes I've made sure its in correct auto position -
Post #805529 9th Dec 2019 8:57pm
thefender
Yup I see dome light is what I'm calling courtesy light - Thanks - I've got that in correct position. In the straightforward on position the come on fine, nothing on the other positions unless as I say you trigger the alarm and then they flash briefly
Post #805531 9th Dec 2019 9:03pm
4RF RDS
Thumbs Up Sounds like the 10AS unit. Sad 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #805535 9th Dec 2019 9:21pm
grafty99
Yes you'd need to plug into nancocom or similar. The courtosey light options are something like Auto, Smart or off I seem to remember Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #805540 9th Dec 2019 9:36pm
thefender
Thank you - that sounds like a goer. I just tried my crappy Carsoft 930i in it but no chance, it can't access that stuff. I noticed when I went out to it to try it that when I use the fob to turn off and on the alarm that the light also flashes once. So, off to find someone local with a Nanocom or Hawkeye with green adaptor. At least its not exactly urgent..
Thanks, when I've managed to try it I'll post up the results
Post #805565 10th Dec 2019 12:00am
landy andy
There are a few on here with Nanocom’s so it may be worth asking, and letting us know where you are. Thumbs Up Thumbs Up
Post #805566 10th Dec 2019 12:16am
thefender
Good idea - I'm in Gravesend close to M25 so can get to anyone in Kent, Surrey and South London (excluding emissions zone I think?)
Post #805567 10th Dec 2019 12:23am
thefender
Well done Grafty99 - spot on - I ended up buying a Nanocom on the group deal, plugged it in and found the interior lights on the as10 were not switched to "smart" - Changed setting and all resolved Very Happy Very Happy
Post #806969 19th Dec 2019 11:46pm
grafty99
Ideal! A simple, albeit expensive, fix Thumbs Up
The nanocom will come in useful I'm sure! You could leave it in for additional engine parameters whilst driving Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #806972 20th Dec 2019 12:25am
