Home > Maintenance & Modifications > 2010 Puma, brake light fuse blowing
Sportacourt
England 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
I have an issue with the brake light fuse blowing when I touch the brake pedal, checked the wires and nothing obvious so replaced the fuse, same thing happened. Anybody got any ideas??
Post #805470 9th Dec 2019 3:31pm
rallysteve
Have you got a towing socket? If so have a good look at that (including the connections on the back), or easier unplug it and see if it solves the issue.
Post #805473 9th Dec 2019 3:49pm
Sportacourt
Hi Steve, thanks for the tip, sadly just checked and all ok
Post #805486 9th Dec 2019 5:26pm
90 Dreamer
pretty sure someone else mentioned a problem where the loom went onto the back door for the 3rd b/light......
Post #805487 9th Dec 2019 5:40pm
Sportacourt
Thanks, looked at that as well, all seems ok
Post #805520 9th Dec 2019 8:34pm
ickle
Was there something with the 3rd brake light surround chaffing the heating element and causing probs - or was that it just stopped the HRW?
Post #805555 9th Dec 2019 10:49pm
Hal
The chafing just affects the third brake light. Fix is to run a power lead directly from loom behind the door card.
Doesn't fix OPs problem.
Post #805607 10th Dec 2019 12:42pm
