Home > Td5 > Grinding when come of gas
Nathanielellis
United Kingdom 2006 Defender 90 Td5 HT Cairns Blue
Hi. Recently have has a loud grinding noise when come off gas at high rpm in any gear. Only last for a 2 seconds and goes.
Car drives normally and doesn't effect anything but it's very annoying and worrying of it's causing damage to something.
Does anyone have any ideas what it could be?
Post #805425 9th Dec 2019 10:02am
landy andy
I would start diagnostics with changing oil on the boxes and diffs. It could be that they are empty, the oil is knackered, or you may find bits of debris, that indicate that you have an issue.
Andy.
Post #805426 9th Dec 2019 10:06am
rallysteve
Check the idler/tensioner pulleys on the alternator belt.
Post #805431 9th Dec 2019 10:29am
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
We had something similar on our Puma. Sounded like the gearbox was about to disintegrate. Happened after we put a lift on the vehicle. Double cardan prop solved it. Might be worth checking prop UJs as they’re easy to look at and cheap to fix. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #805462 9th Dec 2019 2:19pm
Laurie
Transfer box idler thrust bearing?
Post #805503 9th Dec 2019 7:44pm
