Home > Maintenance & Modifications > Replacement horn / TD5 |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2525 |
Hi Enid
You could go for an air horn, what I did was to buy two uprated horns, replaced the original in the standard position then added the second one to the opposite wing (behind the grill in the headlight surround) then ran a wire to link them together. Works pretty well for me and much better than the single original squeaky version. Good luck |
8th Dec 2019 10:50pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10363 |
PIAA dual horns.
8th Dec 2019 11:12pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2200 |
Air horns dont fare well in the water if you are thinking of dunking it further.
I agree with the PIAA twin horns . Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
9th Dec 2019 10:27am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16892 |
I thought that a Td5 was like a Puma and had twin horns from the factory. |
9th Dec 2019 11:36am |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4784 |
Only county spec and up had twin horns I believe. My 90 was base spec from the factory and only had 1. Has 4 now though 2002 90 Td5 Station Wagon
9th Dec 2019 12:02pm |
My 02' DCPU only had a single horn fitted from the factory too.
I used the second horn connection as the trigger for a relay for my loud aftermarket horn. I have also fitted another relay which prevents the aftermarket horn sounding unless the ignition is on so as to keep down the neighbour annoyance when the alarm goes off! Steve 02' 110 TD5 Double Cab Rebuild Thread 84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale |
9th Dec 2019 12:22pm |
My '07 Puma County spec DCPU had 2 fitted but only 1 worked, a sort of half way house between the poverty spec single horn and the top spec twin, perhaps!
9th Dec 2019 8:26pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3025 |
My 2010 XS had 2 fitted but only one was connected. WARNING.
This post may contain sarcasm. |
9th Dec 2019 8:52pm |
ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 218 |
My 05 base van style 90 again only 1 horn, LHS near grille. Installing twin airs made the appropriate truck noise
but did need a relay according to the install kit so you'll need to choose appropriate location for wiring. In the end I chose tucked away under the bonnet on inner wing. Sold the much modified 110 2.8, in Oz Brought the 90 home from Switzerland ... |
9th Dec 2019 11:36pm |
