![]() | Home > Maintenance & Modifications > Tdci heater wiring into 300tdi loom |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6681 ![]() ![]() ![]() |
The two connectors are for the motor and the resistor pack.
Are you using the Tdci heater switch pack? ![]() ![]() |
iceshj Member Since: 16 Jan 2016 Location: Southampton Posts: 28 ![]() ![]() |
Thanks for a reply, what is the switch pack? Defender 90 softop (in bits)
Range Rover Hybrid SVAutobiography Discovery 3 HSE Kawasaki ZX12R |
The 0-1-2-3 slider and the dials from the centre dash panel
Hi, my plan is to use them. I still have the original loom so have all the connections Defender 90 softop (in bits)
Is anyone able to answer this please. All advise gratefully received Defender 90 softop (in bits)
![]() Click image to enlarge TDI 300 has three spade connector to heater speed control ![]() YPC802720 part number for plug TDCI heater control ![]() Click image to enlarge you need plug and pins for the TDCI heater control and make loom adaptor tdi 300 three spade connector for heater speed control behind dash left hand side steering wheel and TDCI heater control in centre of the dash also are you using post 07 heater or old heater box and motor ![]() Last edited by dorsetsmith on 17th Dec 2019 11:42pm. Edited 2 times in total |
![]() Click image to enlarge OK here we go! On the heater box, 2 pin plug is the fan (blower) Pin 1: Path to ground via switch pin 5 and resistor pin 3 (brown/red, 2 connections) Pin 2: "AUX" (key position 1) 12V supply from White/Orange ignition switch terminal via 30A fuse The 3 pin plug is the resistor Pin 1: Ground path from switch pin 2 for Speed 1 (blue) Pin 2: Ground path from switch pin 4 for Speed 2 (black/brown) Pin 3: Output to blower fan and also connected to switch pin 5 (brown/red, 2 connections) The 5 pin plug for the switch is as follows: Pin 1: Ground (black) Pin 2: To Resistor pin 1 for Speed 1 (blue) Pin 3: not connected Pin 4: To Resistor pin 2 for Speed 2 (black/brown) Pin 5: Direct ground path to blower fan for Speed 3 and also to resistor pin 3 (brown/red, 2 connections) FYI the join/splice A495 shown on the blue wire is where the switched earth from the air con fan control relay is joined (so speed 1 kicks in with the air con button pressed). ![]() ![]() Last edited by Martin on 17th Dec 2019 10:45pm. Edited 1 time in total |
300 Tdi heater fan
![]() Click image to enlarge So, the Tdi purple/green is the fused aux feed to the fan, this can supply the 2 pin Puma fan connector on pin 2. The black at the Tdi fan switch is earth and can go to pin 1 of the 5 pin Puma switch connector. You currently have 2 wires from the Tdi switch to the fan. You can use these but you need to add an extra one of 2.5mm2 cross section but it has to connect 3 items. Wire 1 (e.g. Green/Yellow) - used in place of BLUE Tdci speed 1 wire. Goes from pin 2 of Puma switch to pin 1 of Puma resistor Wire 2 (e.g. Green/Slate) - used in place of BLACK/BROWN Tdci speed 2 wire. Goes from pin 4 of Puma switch to pin 2 of Puma resistor Wire 3 (new one) - used in place of BROWN/RED Tdci speed 3 wire/resistor output. Goes from pin 5 of the Puma switch to pin 2 of the Puma fan connector, and also to pin 3 of the Puma resistor. ![]() ![]() |
Thankyou both for your responses. It really is very much appreciated. This will be my project after xmas. Marry Christmas to you all Defender 90 softop (in bits)
