Home > Technical > Fitting Hp24 autobox
The Monkey
Ireland
Hi all about to fit my hp24 box to my td5!
Would I be right in saying that you fit the TC to the pump first and then fit box.
Once fitted you then attach the TC to the flywheel.
Also is it reccomended to change the oil seal in the bells housing and possibly change the filter in the box itself. Although I've changed a few manual boxes this will be my first auto.
Any advice appreciated. 👍
Cheers.
Post #804528 2nd Dec 2019 9:48pm
Hp24? You having the electronics?
Anywho, pumpkin (torque converter) on the pump first, make sure it’s sat properly to avoid damage.
All the information you need can be found on Ashcroft’s site, as well as hints and tips, as well as parts for the filter swap etc.
I had Ashcroft build me a ‘monster box’ best thing i did as it transformed the v8. QRZ M8VPF
Post #804531 2nd Dec 2019 10:27pm
The Monkey
Ireland
Cheers lad! I've a compushift to make it work.
Hopefully 🤞
I'll check out the Ashcroft site.
Post #804532 2nd Dec 2019 10:39pm
