Home > Td5 > Alarm key fob range.
NineCherries
Scotland 2000 Defender 110 2.5 TD CSW Oslo Blue
What’s your alarm key fob range like?
I’ve swapped the battery and it made no difference, I’ve to be at my car and at window height to get it to disarm, and even then i sometimes have to move and press the button again.
Is it just a quirk or can I do something to improve it?
#JustDefenderThings 🤣
Post #803743 26th Nov 2019 11:57pm
lightning
I got a new remote and the range was better, you could try that.
They are not expensive.
Post #803745 26th Nov 2019 11:59pm
JPE
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Firenze Red
Mine's the same. Sometimes it surprises me & opens from a short distance away but generally I have to get really close to the front of the vehicle.
Post #803746 26th Nov 2019 11:59pm
NineCherries
Thanks. Maybe it is normal then. I thought it was possibly faulty. I’ll need to dig out the spare to compare at the weekend, I’m just used to being able to check the car is alarmed from the house with my previous cars. I suppose, on a positive twist, I can’t accidentally disarm it from the house 👍🏼
Post #803749 27th Nov 2019 12:30am
Sulisuli
Hold the keyfob under your chin and push the buttons and I think you will see the range improve, I sure Jeremy Clarkson did this on top gear years ago Rolling with laughter 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #803754 27th Nov 2019 7:07am
hank
There is a mod!
Pictures show a TDCi, but I believe it's the same on TD5
 > 110 XS Double Cab
Post #803756 27th Nov 2019 7:33am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
With mine its a lottery at to how far away it will work.
Rear near side 6" away from indicator lens.
Rear offside between 5' and next to indicator lens.
front nearside between 5' and next to passenger door.
front offside same as nearside.
front up to 20' away.
The above all depends on which way the wind is blowing. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #803772 27th Nov 2019 10:24am
grafty99
For extended range, hold the fob against your forehead Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #803773 27th Nov 2019 10:26am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
Hank's tip above is the same for a TD5, the orange wire normally terminates behind the driver's side speaker, crimp another piece on and run it up the dash and inside the windscreen trim panel. It doubled the range on my Td5.
That said, the forehead option also works and doesn't cost anything Thumbs Up 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #803779 27th Nov 2019 10:59am
NineCherries
brilliant, thanks. Thats another job to add to my list, I'll do that when i'm fitting new speakers. Thanks all Smile
Post #803781 27th Nov 2019 11:34am
Stacey007
Mine normally only opens / locks when I'm near the truck.
In over 4 years it's not really an issue? why do you need it to unlock further.
My last 'car' and wifes current one the book can open clicking the remote form what seems like half a mile.... trouble is accidently on her car the boots been left open twice overnight when I guess the remote has been 'pressed'
It even lets you walk up tp the boot and swipe your foot under it to open (assuming the keys are on you somewhere) has this feature ever been used... Nope Smile
What I would find more useful on my truck is the device that raises the windows when you all jump out and they are partially down... Far more useful Thumbs Up
Post #803805 27th Nov 2019 3:00pm
Mike c
England 2004 Defender 90 Td5 CSW Belize Green
Mine is like this! Wondered if was normal or not, have to seem to be within 5 metres of the vehicle which is very different to most other cars! As pointed out above it's not really an issue, just different when you drive other vehicles regularly, it catches you out!
Post #803824 27th Nov 2019 5:26pm
lightning
I will try the modification suggested above, it would be nice if l could lock my 110 without having to go round the side.
Post #803915 28th Nov 2019 9:28am
doublecabjon
I have the standard alarm for the immobiliser, and an additional Meta HPA system to work the central locking and motion sensors, (I know, a bit overcomplicated. I installed it a long time ago, needs simplification now as its getting a bit unreliable)
Anyway- both key fobs have very poor range! Always have done. And I have the antenna draped across the dash top.
Post #808575 3rd Jan 2020 11:41am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Gonna try this later this week. Top work folks 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #809036 6th Jan 2020 6:18pm
