Home > Tdi > power steering v-belt (defender 200tdI)
sonoronos
Hi folks,
I'm going through and refreshing the v-belts for my truck and have a question.
Based on several references from the internet, it seems part Dayco 17285 (Outside Circumference: 29.27" / 743.46mm) is the recommended V-belt for the Power Steering pump on the Defender 200tdi.
However, I am attempting to place the v-belt on the engine, and for the life of me, I cannot seem to install the belt without completely removing the power steering pump itself.
Should I be able to install the power steering belt on the Defender 200tdi without totally removing the power steering pump?
Yes, I have slackened all three bolts to the maximum.
Shouldn't the belt just slip over the two pulleys when fully loosened? If so, I will just get the next size up belt (17290, I believe) but I want to make sure, first.
Post #802127 13th Nov 2019 8:08pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
Post #802128 13th Nov 2019 8:18pm
sonoronos
thanks tolley, but that's a disco 200tdi?
or are you saying that the belt has to be "rolled on" via rotating the crankshaft pulley?
Post #802176 14th Nov 2019 12:19am
jst
Quite often they are rolled on and many a time I have taken that plate holding the pas pump completely off to get belt on. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #802196 14th Nov 2019 8:17am
sonoronos
Success! The Dayco 17285 "rolled on" to the crankshaft pulley with no issues.
Hard to believe how much these v-belts either vary in length or stretch over time - the old belt was also a 17285, but came off the pulleys quite easily, hence my confusion. 7 year I think on that old belt.
cheers mates.
Post #802683 18th Nov 2019 11:06am
