![]() | Home > Maintenance & Modifications > Door seals |
oneten110 Member Since: 02 Jul 2011 Location: Wish I was still in France Posts: 741 ![]() ![]() |
No, the standard genuine seals are not preformed other than in the corners at the top of the door. It is not a Defender, it is a One_Ten
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
Not the answer your looking for, but genuine is the way to go, yes twice the price but so much better.
Tiger seal would certainly help with the ones you have ![]() 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) Last edited by bear100 on 13th Nov 2019 12:33am. Edited 1 time in total |
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 ![]() ![]() |
On the drivers side the seal has a flat face wher it crimps onto the metal edging strip for security.
The seal I am having to fit has a curved face instead of flat. So wher you would tap it on with a soft mallet there is two different faces, one flat on the driver side and one curved...the awkward one. Is that the difference between after market and OEM. Think Tiger seal is way to go as its drove me crazy 😡 1990 200tdi conversion 90 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4802 ![]() ![]() ![]() |
Definitely go with genuine seals, far superior
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 737 ![]() ![]() ![]() |
Definitely go genuine. These are not preformed but have a metal insert which grips the door frame and will fit the curved area ( you apply downward pressure whist fitting the curve).
The seals are haded left and right too. |
Thanks for the advice👍 1990 200tdi conversion 90
