Home > Wheels & Tyres > What's the Verdict?
SteveK
United Kingdom 2002 Defender 110 Td5 HT Rimini Red
What's the Verdict?
I acquired this on the way home from Somerset whilst towing a 14ft trailer with a car on it!
The bolt has gone right through. The local tyre place insisted it could not be repaired as it is so close to the edge. What's the verdict? I
Post #801846 11th Nov 2019 9:42pm
Bows
Wales 2006 Defender 110 Td5 SW Alpine White
Personally I’d try another tyre place, or Swap it with the spare. It’ll be fine as a get you home spare tyre. Tyres have come a long way in recent years and punctures are almost a thing of the past, so you’d probably never need to use it. I can’t remember the last time I had a puncture. (Touch wood) 😂 2006 TD5110 station wagon
1995 300Tdi 90 truck cab
1989 90 hard top with 200 tdi
1983 110 hard top
1983 110 Hi cap
1954 107 pick up
Post #801850 11th Nov 2019 10:11pm
VVS210
What he said ^^^
I can't see how any tyre repair place can tell you that without taking the tyre off the rim - I'd find somewhere that will do that & see what they say once they can see the inside of the tyre.
Post #801852 11th Nov 2019 10:25pm
That's more or less the exact location I had a tyre cut that ruined the tyre.
As it is, it's not legal nor repairable as it's the tread edge / sidewall.
The only area repairable is the central area of the tread 3/4 width or similar rings a bell.
I'd just stick the spare on for now, then you can go from there. Thumbs Up Diesel$ Live$ Matter. ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #801871 12th Nov 2019 12:25am
rallysteve
BS AU 159 is the British Standard that covers road vehicle tyre repairs.
The standard limits puncture repairs on car tyres to 6mm diameter (at the end of the penetration)
And acceptable repair zones (measured centrally on from the tyre centreline):
Up to and including 155 section width - 60%
Above 155-200 section width - 65%
Above 200 section width - 70%
So nowhere should be repairing a tyre if these conditions arn't met.
Get the tape measure out and see what you think
84' 90 3.9 V8 Caged Pickup Build Thread - Now For Sale
Post #801880 12th Nov 2019 9:12am
SteveK
Thanks for the clarification Steve. I'll have a measure up later.
Post #801926 12th Nov 2019 1:12pm
lohr500
If it is 6mm or less, you could try one of those £6.00 tyre repair kits from fleebay.
Do a search for tyre repair kit.
We used the same kit on a Mitsubishi 4x4 tyre at our sailing club and it worked really well.
I would keep it as a spare though, rather than run on it permanently, just in case the sidewall has got damaged internally.
Post #801948 12th Nov 2019 5:39pm
gilarion
See if there are any Vulcanisers in your area, they would be able to sort out that type of damage easy. I have had worse damage than that nail repaired via vulcanising, It is a safe and durable way of fixing a puncture repair by applying a patch, welding the new and old rubber together to bond. Tyre vulcanising repair can be implemented on any tyre including sidewalls, shoulder and tyre tread surface.
If there are none available in your area it is possible to send a tyre to a further afield vulcaniser via a carrier For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #801959 12th Nov 2019 6:56pm
Oldowner
As it’s a Continental cross contact there must be loads of half worn or spares knocking around, probably cheaper than having it repaired.
Post #802025 13th Nov 2019 7:02am
jst
Move to spare and fix it yourself. https://m.ebay.co.uk/itm/Stop-and-Go-Stand...b4f4b17797
I have been using these kits for last 5 years or so with great success in road legal atvs, or sized rims.
Check the legality of fixing your specific one. Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #802033 13th Nov 2019 7:57am
Stacey007
I would get a new tyre
Don't want to skimp on a bad fix or have any reason to think as your driving along on wet dark motorway that I hope that tyre is ok...
Tyres / Brakes / Suspension the things that keep your car on the road imho not worth a risk.
Post #802048 13th Nov 2019 9:55am
discomog
Is it really worth risking your life and the lives of others for the cost of a tyre? As previously mentioned I'm sure there are lots of unused Cross Continentals kicking around in forum member's garages if you can't afford a new one. Stay safe. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #802049 13th Nov 2019 9:59am
SteveK
Fair comment- even a "get you home" spare can burst with disastrous consequences- I've bitten the bullet and shelled for a new tyre.
Post #802064 13th Nov 2019 1:21pm
