Home > Td5 > Doors not latching
Page 3 of 4 <1234>
landy andy
Bloody fantastic. Cured it. Couple of mins with brake cleaner into the lock and good as new.
Thanks for your help with a very annoying problem.
Andy.
Post #737359 29th Oct 2018 11:49am
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Brilliant! It’s one of those little things that is hugely satisfying to fix. Well done. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #737367 29th Oct 2018 12:57pm
Vogler
Belgium 2015 Defender 110 Td5 HT Chawton White
I read this topic this very morning, thinking I had this issue solved because it had been almost four years since it last happened.
Ten minutes later I had to move the Defender and consequently struggled 15 minutes to close a door. It was the first cold night.... It ab-so-lu-te-ly wouldn't lock until I applied some lockspray used upwards into the lock. Problem solved immediately, it didn't even need a second try!
J
Post #737493 29th Oct 2018 10:58pm
Ashman85
...the Landrovernet linky on the first page doesn't appear to be working?
Could anyone kindly summarize the 'fix' as my rear doors on my 110 are playing up in the cold!
Thumbs Up
Post #738192 2nd Nov 2018 3:06pm
landy andy
For mine it was a case of spraying loads of brake cleaner into latch mechanism, washing or out all the old gloopy stuff then all work brilliantly. Then a quick reoil with thin oil. Gt85 for me.
Andy.
Post #738196 2nd Nov 2018 3:15pm
Ashman85
Cheers Andy.
Appreciate the prompt response... I have cleaner and GT85 in the garage too Thumbs Up
Post #738198 2nd Nov 2018 3:19pm
landy andy
Enjoy. And you will, it’s a very satisfying experience.
Post #738290 2nd Nov 2018 10:39pm
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
I have had problems with my passenger door latch in all weathers since I bought the 90 in March.
I have just followed the procedure and it is working perfectly now.
I just love this forum such a wealth of knowledge on it that people are willing to share.
Thanks 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #738349 3rd Nov 2018 9:19am
RANGER1312
United Kingdom 2001 Defender 90 Td5 CSW Stornoway Grey
My doors have started to almost spring back open when I close them since the temp has dropped and when close them I have to do it firmly and hold it.
Given how it appears to be one of those Defender foibles, I'll give this a shot at the weekend to see if it makes a difference Thumbs Up
Post #746658 20th Dec 2018 9:28pm
Landish
United Kingdom 2005 Defender 90 Td5 SW Belize Green
This is a brilliant fix! With the colder weather, my passenger door has been bouncing open when you slam it and would only latch intermittently if you kept pressure on it when closing from outside.
I tried the procedure with brake cleaner and the latch was working perfectly again within a couple of minutes. Now planning to spray in some light oil and will keep the brake cleaner handy for if/when it happens again . . . . 2005 Defender 90 TD5
Post #801633 10th Nov 2019 5:20pm
lightning
Yep, same here, passenger door bouncing open when shut.
Unable to open the link on page 1 but l sprayed the mechanism with WD-40 and it now works fine.
Be aware that the latching mechanism is ABOVE the latch and not below. So if you are spraying WD-40 or similar in to it (without dismantling the door) then you need to direct it upwards into the mechanism.
Post #801661 10th Nov 2019 7:12pm
markb110
Its that time of year folks so i thought i would resurrect this thread to remind / help others and to save searching for it.
And yes my passenger door has just started to do this which always coincides with the MOT.... Rolling Eyes
All fixed.....again Thumbs Up
Post #871029 2nd Dec 2020 11:03pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Tried the brakecleaner trick today on the 110 Td5 ... spectacular result Bow down
Used almost a full can because the locks were very sticky, but this really works very well Thumbs Up Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #871706 6th Dec 2020 11:37pm
PCM
Does anyone have an image of where exactly the cleaner needs to go?
Post #871717 7th Dec 2020 1:01am
markb110
It’s 1.30pm and the garage has not called me so I am guessing that it has passed the MOT that was booked in at 10.30 for.
On a side note on my 90 under the plastic spacer (under the door latch) I have a heep of the 1mm spacers. This I have noticed allows the latch to move flex ever so slightly when closing, re slamming the door closed, and hence does not fully engage the door catch. Though oddly not a spring summer problem.
When I get the car back I will be replace the 1mm spacers with a square of 4mm alloy square and spray it to match the body colour.
Post #871791 7th Dec 2020 2:42pm
Page 3 of 4 <1234>
