Home > Off Topic > Water Pump Recommendations
Not the vehicle type but one to pump out the 1/2 acre lake growing in my garden.
Can anyone recommend me one?
I think I would like a Honda engine, 2" hose size, be able to deal with reasonable size solids, although I know nothing about them really so I am happy to be guided by someone with knowledge. Hoping it will be man portable at least being able to be lifted off a shelf, into the back of a vehicle etc.
Any help welcome.
Post #801352 8th Nov 2019 3:42pm
Rashers
I feel for you there, Supacat.
I am not sure anything you would buy would (sensibly) be able to deal with that amount of water.
I've been on sites where the Fire Brigade have pumped out basements and even with their high capacity pumps, it takes for ages.
If the water is coming in from an adjoining property, it would take for ever.
Post #801353 8th Nov 2019 3:53pm
Hey
understand what you are saying but thought something pumping 600 litres a minute, or thereabouts would help clear this mess and at least give the ground a fighting chance to take some more water next time it rains?
Post #801356 8th Nov 2019 4:21pm
How about a classic Coventry Climax Godiva fire pump? 1600 lpm, man portable. Usually at least a couple on eBay around the £500 mark.
Post #801367 8th Nov 2019 5:50pm
Tim in Scotland
Your problem will be where to pump the water to if all around you is also flooded, it will be like trying to pump out a lake with several rivers still flowing into it unless you can sand bag around your house and pump that water out to the other side of the barrier. I feel for you, especially at this time of year when everything takes for ever to dry out. Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
Post #801368 8th Nov 2019 5:55pm
Thanks chaps for the comments and suggestions, hadn't thought of the Godiva in particular, will have to research that further.
I'm hoping I will be OK with pumping it off to several places around the property that are lower. Main thing is to move it away from the outbuildings and the septic tank.
Post #801386 8th Nov 2019 8:10pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
diesel powered dirty water pump, 4" pipe
Post #801399 8th Nov 2019 9:27pm
Sulisuli
That’s a lot of water to shift. We use submersible pumps at work rather than the type of pump you suggest. Run off a generator you can use the generator for other tasks when not needed for running the pump. Normally 110 volt, don’t use 240 volt !!!
All small pumps will struggle pumping any kind of solid and I’m calling small anything below 8” or 200 mm.
Submersible pumps will give you a better head (the distance upwards they will pump)
Flygt pumps are our go to choice of pumps. Thumbs Up
Hope this helps 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #801402 8th Nov 2019 9:55pm
dorsetsmith
Powerful 208 cc, 7 hp 4-stroke petrol engine
RPM: 3600
Run time (75% load): 3 hours
Maximum output flow: 750 l/min
Maximum output head (lift height): 23 m
Maximum suction head: 8 m
Rated max. pressure: 2.3 bar (33.3 psi)
Outlet size: 3” BSP
Pump body can pump solids in suspension up to 15mm dia.
Supplied with hose connections and intake strainer
Dimensions (L x W x H): 530 x 425 x 465 mm
Weight: 24.3 kg
Post #801406 8th Nov 2019 10:05pm
Zed
That's grim. I hope it hasn't ruined too much.
Has it flooded before? WARNING.
Post #801528 9th Nov 2019 7:24pm
