Home > Td5 > One way central locking....
JOHNT01670
United Kingdom 2006 Defender 90 Td5 SW Zermatt Silver
2006 TD5 90 central locking issue...
I have had all 3 doors apart, cleaned all locks with brake cleaner and lubricated with silicon spray they are all free moving.
Removed the locking motors, again free moving and reinstalled - only anomaly at that stage was the drivers door lock was activating when I was putting it back in place but did not get the same reaction from the rear and passenger door??
Changed batteries in both fobs and checked fuses under dash.
So the car unlocks all 3 doors from the fob but wont lock them. When the lock is pressed the indicators flash 3 times and the red light activates in the speedo. All Doors have to be closed/locked manually.
Any ideas folks??
john 2006 TD5
2002 Honda Transalp 650
1995 Yamaha Vmax 1200
2014 Nissan Juke (wifes)
Post #801030 6th Nov 2019 3:30pm
dorsetsmith
do you have use of a voltmeter Question
10AS alarm unit swaps pos and neg over in the two wire to open and close the door locks, the feed back from the drivers door lock is also in-portent too so alarm unit nos if locked or unlocked state
driver door switch also in-portent too so alarm unit nos if door not closed but ajar
Post #801032 6th Nov 2019 3:38pm
JOHNT01670
Hi Dorset,
I can get hold of a voltmeter - i'm OK to use for basic testing... 2006 TD5
Post #801079 6th Nov 2019 7:33pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Check your bonnet switch... Thumbs Up 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #801125 6th Nov 2019 10:14pm
JOHNT01670
Thanks folks, will check bonnet and door switch (drivers) next.... here's hoping I get a result.
John 2006 TD5
Post #801181 7th Nov 2019 11:58am
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
What happens if you attempt to lock the doors from the drivers door switch rather than the fob? It might just be that one of the door switches is not being closed so it thinks there is still a door open.
In this situation, after locking the car from the drivers door the doors will immediately unlock.
Tony
Post #801187 7th Nov 2019 1:02pm
JOHNT01670
Hi Tony,
When using the key to lock the drivers door, the passenger/rear doors do not lock, they also have to be manually closed. Once all 3 are locked, the fob can be pressed (to lock doors) and the indicators flash, red light on speedo activating the alarm.
After this has been done all 3 doors will unlock via the remote fob.
from info provided I feel that the culprit could very well be one of the door or bonnet switches.... hopefully... 2006 TD5
Post #801190 7th Nov 2019 1:17pm
kzycnn
Hi John
I don't mean using the key, but the internal button on the drivers door. If the solenoids don't fire up using the key from the drivers door lock, that could simply be adjustment - my doors can take a few attempts to trigger the solenoids if I attempt to lock the car using the key (since changing the doors and moving the locking mechanism over).
So, if you press the button on the drivers door and the doors lock then immediately unlock, then that is symptomatic of a door switch (the alarm thinks a door, or bonnet, is still open).
Tony
Post #801198 7th Nov 2019 2:07pm
Maybe possibly a broken wire in the door rubbers? ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #801199 7th Nov 2019 2:13pm
JOHNT01670
Thanks for the info...I shall investigate further as soon as the rain stops
Help appreciated folks as always
John 2006 TD5
Post #801261 7th Nov 2019 8:19pm
JOHNT01670
When the drivers door is locked from inside by pressing the latch down there is no response from the other 2 doors and the latch remains down ..... 2006 TD5
Post #801843 11th Nov 2019 9:10pm
4RF RDS
Sounds like a broken wire or one is disconnected... Suggest you remove the the door panel and have a look at the solenoid and the rubber wire covering at the hinges. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #801845 11th Nov 2019 9:31pm
