![]() | Home > Technical > Electrical gremlins td5 |
| Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2677
Been working on a td5 for last few days, suspension setup etc did the front speakers also
Tried to start it up today; no electric windows, rear fog lights or high beam? High beam works one way but unable to keep it on, Any thoughts, checked all the fuses but can’t find anything definitive online other than ‘bad earths’ Thanks Liam |
| grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4803
My bet would be a disturbed cable on the back of the ignition switch
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6732
Check Fuse 15, it's the common supply link with all the above.
If not that then the security of the earth header with the ring on the bulkhead behind the coolant expansion tank. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
Though if it was this earth I'd expect a lot more to be off.
2015 D90 XS SW |
Thanks Martin, fuse was the issue..
Last time I trust someone they’ve checked all the fuses |
| All times are GMT |
