Home > Technical > Battery Conditioner Mounting Location?
MalithS
Hi All,
So I've got a LR battery conditioner (CTEK) which comes with the cigar lighter type plug and socket. Im just trying to work out where I should mount the socket somewhere inside the car. Anyone got any pics of installation locations? I'd rather not drill/cut into any metalwork if possible (like battery box area) so wondered where others might have fitted such sockets.
Thanks,
MalithS
Post #801014 6th Nov 2019 11:44am
discomog
Alternatively if you have 13 pin or 12s towing socket you can charge through that rather than cutting holes in your dash etc. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #801016 6th Nov 2019 12:06pm
It depends, to a large extent, on how you want to use it and your parking cirumstances. Discomogs' suggestion is by far the easiest but may not suit if there's the risk of it being tampered with.
If it's for occasional use when away on holiday or for work, for example, then a fly lead into the battery box might be sufficient. If for more regular use then I've seen the socket cut into a switch blank on the dash. Another solution might be to set it into a bit of aluminium angle that could be bolted to the passenger seat runner with the wire passing through one of the rubber grommets in the top of the battery box. I'm sure there are other ways that the same could also be achieved. Darren
Post #801017 6th Nov 2019 12:17pm
MalithS
Thanks for the suggestions. Id rather not use the trailer socket as I use this charger on other cars. I sometimes park up the defender and it can sit for 4-6 weeks without being driven. At the moment I have the charge wire hanging out in the cabin out of the battery box but I'd rather run it nicely under the carpet to maybe somehwere under the dash area. It would be nice to have it neatly fitted (maybe I need t sit in the car and have another look for locations).
Post #801020 6th Nov 2019 12:29pm
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
I use a C-tek comfort connect jobby with 30cm of fly lead direct to the battery. The plug sits besides the passenger seat runner and is relatively unobtrusive. Then charger then sits on the passenger seat (so i don't forget to un plug it) with an extension lead running out of the bottom door seal to the house. 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #801026 6th Nov 2019 1:43pm
Charging in this way is done via an adapter (that can be bought via the forum shop) so doesn't preclude using the charger elsewhere. Darren
Post #801027 6th Nov 2019 2:03pm
gilarion
Just use one of these leave it connected to the battery and as an added bonus it shows you the condition of the battery via leds. Safety fuse included in the link so very safe
https://www.ebay.co.uk/itm/CTEK-Comfort-In...Sw7FFdvFlb For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #801034 6th Nov 2019 2:55pm
https://www.defender2.net/forum/topic17923...p;start=15
Have a look here, has to be the best solution possible.
Post #801036 6th Nov 2019 2:58pm
R1200GS
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Keswick Green
Thanks for the tip Gilarion, just what I have been thinking about. Now ordered.
Post #801039 6th Nov 2019 3:11pm
Mo Murphy
... and charging via the cigar lighter will only work if it is live with the ignition off.
50 Shades of Pennine Grey
Post #801045 6th Nov 2019 3:44pm
Litch
My CTEK is mounted on the centre bulkhead between the seats and I feed through the cigarette lighter (which is permanently live).
Mains power comes in through a flap in the rear and I have a mains lead hard-wired in the vehicle, connects to a weatherproof socket fitted to the house wall just behind the spot where the LR lives. ONE LIFE, GET IT!
Post #801099 6th Nov 2019 8:11pm
Can you show a photo or two of that setup?
Post #801141 6th Nov 2019 10:42pm
