![]() | Home > Maintenance & Modifications > Anyone have experience of bilstein and fox? |
| Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921
Thank you, but bother it, my wallet was hoping it wasn't worth doing...!
I'd better change a few more tap washers. |
This forum can be very bad for the wallet.
New Alive Eibach rear ARB ordered yesterday.... "I tried to resist, honestly darling. Let's pop to the shoe shop later"! |
| Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3788
Bloody hell Joe! Let me know how it feels, hopefully it’s rubbish!!!
One thing I have no ticked is that the rebound on the fox is quite harsh on the rear compared to the front. At first I though something was loose as there is a bit of a knock when direction on the shock is reversed, most noticeably dropping into a hole then coming out, rather than hitting a bump. I’ve checked and double checked every thing and can’t find anything loose and it wasn’t doing it before the damper install. Any thoughts or is this normal?
| MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380
Co1
I think you need to investigate further there is not any knock from mine, are you able to establish which side it comes from? Could you have a defective shock? 2016 Defender Landmark 90 2005 Defender CSW TD5 90XS |
Comes from both sides on change of direction of the shock stroke. I have a speed bump at the end of the road that I can hit with one wheel or another and it happens at both sides. Spoke to Fox who said it could just be stiction on a close tolerance bush/seal in the shock. Have had this a few times on MTB forks so I’ll give it a bit of penetrating oil and run it for a couple hundred miles. I’m relatively confident all the other bushes are OK as there were no knocks before and I had them all checked out about a month prior at MOT time.
| 90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2309
How costly out of interest??
What, the fox’s? Given that my wife bought them for me; nitto!! If your buying them yourself, paddock have the best price at about £115 plus vat per corner.
| X4CAC Member Since: 30 Apr 2018 Location: Midlands Posts: 212
Here's another site to give you even more choice... depending on budget!
https://www.prolinx.biz/Catalogue/Shock-Ab...ver-Shocks |
I’ve still got a knock on rebound on the fox install at the rear. I think it is the top mounting hardware. i didn’t have the OEM washers etc so made a comical washer to sit against the mounting bracket, then mounted the shock, then a dome washer and then the nut. It feels like the nut is bottoming out before the bush is properly compressed. Can someone that has fitted these advise on how it goes together at the upper mount, or even better share a few pics??
Cheers Col |
| Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4808
Glad you have got it sorted now
2008 SVX 90 2000 XS TD5 90 |
Cheers Simon. It’s taken a bit of fettling. The Fox Lower bushes were so Stiff they were preventing proper articulation of the joint. I’ve replaced them with standard LR bushes and it has made a world of difference. There is a still a light clunk at extremes, so whichever bush that was being over-articulated before still needs sorting (once I find it!), but the difference in ride is remarkable.
One thing you will be pleased about is that Liam (LikeOMG on here) came round last night to pick up the old bilstiens and now having looked around his 90 it looks like I’ll be spending a few more quid on mine yet, possible starting with an alcantara head lining! There are now 2 of you to blame for my descending bank balance! |
I put my new Eibach rear ARB on yesterday (it took less than 45 minutes to do) so I'll report back on how it feels when I'm back at work next week.
I just hope I don't then decide I need the Fox kit too.... |
Joe you do you really do
| All times are GMT |
